Which Welding Gas And Where From?
Posted 01 August 2017 - 02:41 PM
I've seen lots of options including co2 and argon/co2, as I understand it the argon/co2 will be better, is that right?
I'd also like a recommendation on where to get it from? Ideally a rent free bottle because I won't be welding everyday, I need to do sills and a few patches.
Anyone here used adamsgas?
Thanks for the help
Matt
Posted 01 August 2017 - 03:13 PM
Rest of my gases for tig or stainless (argon , argoshield) I get from a local welding supplier
I had a quick Google and found the following near you
http://www.andoverpa....uk/13/Pub_Gas/
http://www.thehomebr...ead.php?t=55319
Merv
Posted 01 August 2017 - 03:19 PM
http://www.ebay.co.u...bIAAOSwax5YuCKX
http://www.ebay.co.u...SqwTxNTx4hILXRw
Posted 01 August 2017 - 07:00 PM
I use 5% argon/Co2 mix from motorparts direct, It is a reseller of SGS gasses,
according to the sgs website your local outfit seems to be dorset autospares in Andover
http://www.dorsetautospares.com/
also for shielding gas info;
http://www.bernardwe...91#.WYDPQemQyUk
"Adding argon to a CO2 shielding gas is also an option for materials like carbon steel. It provides consistent weld quality and appearance and good weld pool control, and can help minimize post-weld cleanup"
Edited by Simont, 01 August 2017 - 07:03 PM.
Posted 01 August 2017 - 07:05 PM
Really depends on how much you plan to use it, more than 1 refill on a hobby weld and the boc deal works out cheaper.
I managed to empty a hobby weld cylinder in one weekends worth of welding when I started my project,
Posted 01 August 2017 - 08:01 PM
Posted 01 August 2017 - 08:33 PM
Posted 01 August 2017 - 08:34 PM
Posted 01 August 2017 - 09:28 PM
Merv
Posted 01 August 2017 - 10:38 PM
£20 and no deposit!?Pub bottle are about 20 quid a refill and no deposit, your call. Personally never had an issue . I've used it for body repairs for many , many years with no problems.
Merv
Only just looked at the link to andover patio centre, been in there before.
My welding is crap anyway so I'm going to have to clean it up loads so may as well use co2 if people find it ok, I did test co2 and argon/co2 back to back with the little canisters and the argon did seem more stable less spitting.
Posted 02 August 2017 - 12:23 AM
Get yourself a flow meter instead of a pressure type gauge and if your welding steel 5% Argon is good for most steels. Cant offer advice on where to buy as I'm in the USA. Bottle rentals went out years ago...............
Posted 02 August 2017 - 10:02 AM
Posted 02 August 2017 - 02:41 PM
Looks like the £22 price quoted is for a 6.5Kg bottle .. That's basically the same size as a small fire extinguisher bottle, so depending on your usage it wont last that long. A BOC Size Y bottle weighs in at 40KG full.
I was a BOC customer for years, switched to SGS, but when SGS hiked up their prices switched back to BOC on the Volkszone deal - it's a great deal and you get the choice of Argonshield mixes and also pure Argon if you want to start playing with a TIG.
As above, It all depends on your usage ...
Edited by DomCr250, 03 August 2017 - 01:32 PM.
