Hi there,
I'm having some problems with the brakes on our 1988 Mini Mayfair (with servo).
A few weeks after a new rubber hose was fitted to the offside front, the brakes starting sticking on. Took off the wheel and opened up the bleed nipple and it became unstuck. Bled the brakes and there were lots of little bits of rubber coming out (which blocked up the non-return brake bleeding hose I was using). -> Faulty brake hose I thought, breaking up inside and blocking the caliper so fluid couldn't flow back out.
Anyway, switched the front hoses out for braided hoses (forum was a great help), bled the brakes and there was no sign of rubber sediment. But the same thing happens after a drive. Note, it doesn't bind immediately - only after a short drive. And seemingly only after a drive (pressed brakes many many times while parked up but no locking up happening).
The vacuum seems fine - pulled the vacuum hose off the servo and there's plenty of suction there.
Another thing I've noticed is pressing the brakes hard really drops the revs - to the point of stalling if it's not quite up to temperature. Not sure what this could be?
So now I'm thinking it's master cylinder or servo. Or could it be something else? Caliper? Is there something I could test before forking out for a replacement?
Thanks for your help!
Sam
