Steering Rack/column Spline Specs?
5 replies to this topic
#1 nicklouse
  • 18,662 posts
Posted 04 August 2017 - 09:37 PM
As above what is the spec? Diameter and spline number so I can order a UJ to fit.
Cheers.
#2 Spider
  • 15,059 posts
Posted 04 August 2017 - 09:53 PM
9/16" Dia x 36 spline.
If I recall, CBS has suitable joint.
#3 nicklouse
  • 18,662 posts
Posted 04 August 2017 - 09:56 PM
guess where i had just been looking.
yep a step up UJ was what got me thinking. will be needing to change my seat. it was tight before and now, we it aint going there. so drop a new seat lower and fit a UJ and a decent set of bearings.
#4 nicklouse
  • 18,662 posts
Posted 04 August 2017 - 10:37 PM
Ok, now a thought if i was to fit one UJ would i need to fit on or two support bearings on the other shaft?
i feel that two would be needed. i know on the GTM (extended Mini column) i just had a single bearing and used the rack as a second. No UJs just a long rod straight to the heart.
#5 Spider
  • 15,059 posts
Posted 05 August 2017 - 02:38 AM
While 2 bearings to support the column sounds right and would be desirable, it would be difficult to set up and then maintain alignment given what you have to mount them on, unless a stout mounting frame was fabricated to support both mounts, that in turn was fastened to the body.
You'd be OK with a single mount.
#6 tiger99
tiger99
  • 8,584 posts
Posted 14 August 2017 - 08:04 AM
Yes, and ideally a self-aligning bearing so hat it dous not need to be mounted extremely precisely. You get industrial things called pillow blocks that may be suitable, if they come in the right size. Or you could fit a needle roller inside a large rose joint or uniball to get the self-aligning feature.
