I've discussed this before a few times but finally made a video to demostrate a couple of the issues my car is STILL having.
(search 1RfiNv8VTrQ on youtube if link does not work)
This was done on a well warmed motor. If I burry my foot into the pile at idle, the car misses and sputters until it gathers itself and revs. On the reverse, the idle falls to 1000-1200 for a second or two before settling to 850 or the likes. This has been an issue I have notice for some time. I just put the car back on the road after rebuilding the head and cooling system due to a burst rad hose and an overheat issue. Motor is VERY healthy. Great oil pressure, good consistant compression, water temp never fluctuates. Unit recently, it pulled brilliantly as well. Today is the first day I have driven it since the head/coolant work and there is a hesitation happening, especially noticeable in 4th. Has a hard time pulling in the lower rev range and I can sometimes feel like the car is held back/bogging at times. If I blast through the gears to redline, 1-3 feel great but 4th gives at stutter/boggy feeling around 4-5...but that at a pretty high speed so I haven't had too many times to retest.
One thing I have felt for a bit is that the car is VERY touchy in first at low RPMs. On and off the throttle in, say a parking lot, the car can buck a bit if not very careful
Being in the states, i do not have easy acces to a scanner but all previous times I have plugged it in, everything has checked out. All my vac lines have been replaced with proper silicone units. Heated intake unit has been removed complete, plugged and MPi air intake arm fitted to stock SPi airbox. New fuel trap just to be safe. I did remove the Pressure temperature compensator and noticed its trashed. Sounds like there are magic beans inside of it. I reinstalled and will just leave as is. Exhaust is newish and has been de-catted. Replaced the Lambda a bit ago but have not tested lately. I recently sprayed starting fluid around throttle body to see if there are any strange leaks and nothing came of it.
Just trying to give any info that might help...even if a bit long winded. Any thoughts?
Edited by brivinci, 08 August 2017 - 08:45 PM.
