Race car.
cooling set up based on the MPi but no heater and there is a take off on the head.
so i was thinking about having a electric on/off temp sensing switch to work with the electric fan and also with the (not yet fitted) electric water pump.
i do have a capillary type but not keen in the fitting method.
then i remembered i had
Ohh thread the outlet and blank it off and use a sensor hole for a sensor.
hang on why not use the outlet like
current set up is like the above but without the sandwich block and connecting pipe. the bottom hose is just closed off.
so thoughts? restrictors?
