Manifold Stud Removal
5 replies to this topic
#1 MiniMad117
MiniMad117
  • 11 posts
Posted 12 August 2017 - 09:48 PM
Okay first I have done a search and couldn't find anything on this... probably me being thick.
I have an 1100cc A series engine with bent and dodgy (someone has cross threaded in the past) exhaust/inlet Manifold studs. What is the best method of removing them and fitting new ones?
This is for a 1979 Austin/Morris mini 1100 special engine.
Thanks in advance:)
#2 nicklouse
  • 18,640 posts
Posted 12 August 2017 - 09:53 PM
two nuts locked together.
then clean the threads and fit the new.
#3 Shooter63
Shooter63
  • 1,057 posts
Posted 12 August 2017 - 10:03 PM
If you haven't got enough thread for the above method, get a left hand drill bit and drill out the stud ( drill running backwards obviously)
You would be surprised how many studs/ sheared bolts will come out like this
Shooter
#4 Cooperman
  • 23,309 posts
Posted 12 August 2017 - 10:15 PM
I always use 5/16" UNF x 1.25" long hex. head screws to fit the manifolds. This way it is easy to remove the head should that be necessary.
#5 RooBoonix
RooBoonix
  • 1,225 posts
Posted 13 August 2017 - 07:50 AM
This is what I've done, following Cooperman's advice. However, I found 1.25" to be slightly too long so I had to use 1" screws.
#6 ACDodd
ACDodd
  • Mini Docs
  • 2,760 posts
Posted 13 August 2017 - 07:51 AM
Sometimes heat is needed as they can be very tight!
Ac
