Fletcher Radiator Drain Plug
8 replies to this topic
#1 MiniMoe2008
MiniMoe2008
  • 163 posts
  • Local Club: None Around Here
Posted 17 August 2017 - 06:33 PM
Hello all!  So I just bought a Fletcher 2 core radiator from MiniSport. Looks amazing by the way. What I'm trying to do is add an electric fan to it using a temp switch that I want to attach to the drain plug area. Only thing is, I don't know what the thread size is. Does anyone know? Thanks in advance.
https://www.minisport.com/c-ara5100ms-alloy-2-core-hi-flow-side-mounted-radiator-to-suit-all-mini-models-1959-92-except-injection-models.html
#2 smurfomatic
smurfomatic
  • 460 posts
Posted 17 August 2017 - 08:55 PM
I've recently done the same thing. It's an M14 thread, which is a common size for fan switches. I've got one from a Volvo 340 which does the job, it's just a matter of finding one that suits your needs temperature wise.
#3 MiniMoe2008
MiniMoe2008
  • 163 posts
Posted 17 August 2017 - 09:18 PM
Mad, Thanks alot man!! I really appreciate the help. I'll probably do the temp @ 200F/93C just slightly warmer than what thermostat would open at. I'm driving the car from Germany from Spain and Portugal.
#4 smurfomatic
smurfomatic
  • 460 posts
Posted 17 August 2017 - 09:33 PM
You should easily find one that switches at 93, the one I've bought switches on at 87 as I've had problems with the car overheating in the past.
#5 MiniMoe2008
MiniMoe2008
  • 163 posts
Posted 17 August 2017 - 09:39 PM
Really? Do you have an upgraded engine? I just had my 1275 bumped to 1293. Thats why I want the extra cooling. I'm hoping the fan should be enough. If not, I'll also add oil cooler with a fan on it. LOL
#6 smurfomatic
smurfomatic
  • 460 posts
Posted 18 August 2017 - 08:00 AM
It's not an upgraded engine, but the radiator is front mounted so the air flow isn't as good.
#7 cal844
cal844
  • 9,623 posts
  • Local Club: TFMOC
Posted 18 August 2017 - 10:02 AM
Why not just wire the fan to a switch on the dash? You can manually switch it then instead of assuming it's on
#8 Midas Mk1
Midas Mk1
  • 5,779 posts
  • Local Club: S.U.N.M.C
Posted 18 August 2017 - 10:11 AM
Even better, temp sender in the rad, and a manual override with illuminated switch, best of both then.  I did this with my MPi as a backup to the sender.
#9 MiniMoe2008
MiniMoe2008
  • 163 posts
Posted 22 August 2017 - 04:20 PM
I rather let the temp sensor do the work.
Edited by MiniMoe2008, 22 August 2017 - 04:21 PM.
