Windscreen Vent Removal
Posted 22 August 2017 - 06:24 PM
Just a very quick on to give me a heads up before I snap the things at the weekend...
Need to remove the find screen vents from the upper dash pad in order to place the vinyl trim underneath it and then re-secure. Is it just a case of pulling them out? Or are there clips/ screws holding them down? I don't want to go hell for leather with brute force and ignorance only to find myself on eBay buying a new set.
Cheers guys and girls!
Posted 22 August 2017 - 06:30 PM
two screws. one at each end.
but age and version of Mini might help as there may have been changes.
Posted 22 August 2017 - 06:38 PM
Cheers mate. It's a 1972 Morris Mini although it looks like its seen an interior change throughout this time as its got a 3 clock walnut dash. Guessing its just a case of dropping the walnut dash off and accessing the vent screws that way?
Posted 22 August 2017 - 07:05 PM
there are push in covers for the padded upper. under there there will be two screws that screw into the vent head.
Posted 22 August 2017 - 07:13 PM
https://www.ebay.co....tm/292205803787
If so, these are what I am looking to remove. These are just push fit?
Posted 22 August 2017 - 07:16 PM
yes but they might be a slide in fitting needing the dash pad to be removed. years since i have had one.
Posted 22 August 2017 - 07:18 PM
Thanks for all of your help!
Posted 22 August 2017 - 07:24 PM
Yes -It will snap.
They pull out from the front, which means removing the dash, & i've always done that without a windscreen in.
Posted 22 August 2017 - 08:29 PM
Edit: spelling
Edited by Marc_mcq, 22 August 2017 - 08:45 PM.
Posted 24 August 2017 - 10:34 AM
