Ok, so I'm replacing the front suspension bits with stock standard. I have now got to the point where (after much beeping and bleeding), that top arm is out of the car. The problem I have now is that the nylon cup and knuckle joint (and the trumpet, which is not so bad as it's giving me leverage) are still attached to the arm. Any recommends on how to get them out of the arm so that I can replace with new? The nylon cup was already toast and the existing grease is like cement paste, so I can't really put it back without renewing the cup and the knuckle.
I eagerly await your replies, and will put the kettle on.
Thanks all,
G.
