Hello Guys and Girls,
The original engine from my mini is currently part way through a rebuild and is completely stripped apart from the crankshaft, con-rods and pistons. I can't remove these until I've taken the gearbox off but I'm struggling to separate them. I've removed all the bolts and nuts I can see that hold the gearbox casing to the block but they still seem to be stuck together. Am I just being thick and missed something obvious or could they have rusted together - I'm pretty sure this is the first time they've come apart since being built in the factory!
Obviously, using something like a chisel to bang in between the block and the gearbox casing isn't a good idea so I might try suspending them from the engine crane slightly and gently tapping the gearbox casing downwards with a rubber mallet or something.
Has anyone got any ideas as to why they might not be separating? It's a 998cc A+ engine from a 1989 racing flame is that makes any difference.
Thanks,
James.
