Recommend Me A Air Compressor
10 replies to this topic
#1 Laurie
Laurie
  • 298 posts
  • Local Club: GMOC
Posted 25 August 2017 - 08:18 PM
Following on from the air gun thread which I didn't want to hijack and I'm still painting by hand the bits I can, but I want / need something for the bigger bits / laquer
I also want to get some air tools, so what bar do I need? Is 8 or 10bar sufficient?
I was looking at this
http://www.halfords....1&storeId=10001
Or this
https://www.machinem...pressor-with-a/
Help
I'll check the other thread for spray gun recommendations x
#2 Daz1968
Daz1968
  • 2,058 posts
Posted 25 August 2017 - 08:53 PM
None of those are really suitable for air tools or full sized sprayguns. Best bet is a 3hp belt drive 14cfm or a hydrovane 3hp, although latter is expensive. There are some good deals on belt drive, some around the £300,
I have a Clarke industrial 3hp with 100 litre receiver and it works fine with most tools. Dont forget if painting budget for correct water traps and filters
#3 MINI WILL
MINI WILL
  • 559 posts
Posted 25 August 2017 - 09:10 PM
I've got this one had it for over a year now I haven't used it for spray painting just blowing tyres up and blowing dirt out of the way.
It even comes with some handy attachments.
Link
#4 Laurie
Laurie
  • 298 posts
  • Local Club: GMOC
Posted 25 August 2017 - 09:58 PM
What about this one:
Bostitch C24U110 110V 24L Portable Compressor https://www.amazon.c...i_80jOzb3KJBVZM
#5 panky
panky
  • 1,792 posts
Posted 25 August 2017 - 10:09 PM
Still a bit small I think and it's 110volts.
#6 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,074 posts
  • Name: Neil
Posted 25 August 2017 - 10:16 PM
I have two compressors. One is a 3hp V twin 100 ltr Clarke unit and the other is a single cylinder 4hp 200ltr unit from Magnum.
The first one will run most air tools but not at full speed, however for painting i will be using this for my breathing air with a three stage filtration system.
https://www.machinem...RgaAkGjEALw_wcB
The second
https://www.google.c...-Xrj-wqQ5Ur0WM:
This runs everything, DA's high speed grinders etc and is perfect for spraying as well.
So going on from that, the bigger the better. It gives you the luxury of being able to use it for virtually anything you need it to do.
#7 Laurie
Laurie
  • 298 posts
  • Local Club: GMOC
Posted 25 August 2017 - 10:37 PM
I'd look at hiring one, but been on their sites and they're a bit big to be honest, bit like your second one there Sonikk lol
Edited by Laurie, 25 August 2017 - 10:37 PM.
#8 DomCr250
DomCr250
  • 667 posts
  • Local Club: 16V mini club
Posted 26 August 2017 - 12:25 PM
There is normally loads of secondhand stuff on ebay ... dont be put off if it's three phase, you can easily swap the motor over for a single phase one.
#9 sonikk4
sonikk4
  • 16,074 posts
  • Name: Neil
Posted 26 August 2017 - 01:16 PM
A lot depends on your budget. Machinemart do VAT free nights so an ideal time to buy the largest Clarke compressor you can afford.
The Magnum compressor I have you can get for £350 second hand. It's a big beastie, a tad noisy but will do anything you need to do in your garage.
#10 cubby1701
cubby1701
  • 187 posts
  • Local Club: causeway coast mini club
Posted 27 August 2017 - 02:18 AM
Frost have some decent ones including a few vertical 100ltr for good money
#11 Bradchap
Bradchap
  • 53 posts
Posted 29 August 2017 - 04:29 AM
I've got the 90 litre belt drive 14cfm from gtair.co.uk, can't fault it, used it for spraying and air tools.
