High Capacity Oil Pump
Best Answer Ruth's Mini , 05 September 2017 - 10:19 AM
great discussion points
thanks everyone
Go to the full post
10 replies to this topic
#1 Ruth's Mini
Ruth's Mini
  • 104 posts
Posted 04 September 2017 - 08:59 PM
does anyone supply a higher capacity pin drive oil pump for an 850 Mini?
thanks in advance
#2 nicklouse
  • 18,605 posts
Posted 04 September 2017 - 09:05 PM
sure you can get them but pin drive is not that strong and you dont really need a higher cap pump for anything other than a turbo.
what issue thinks you need one?
#3 mini13
mini13
  • 3,810 posts
Posted 04 September 2017 - 09:09 PM
you can swap in the 1275 pin drive with a spacer plate, IIRC the early 850 pumps were smaller than what we have today.
if you cant get the 1275 pin drivemight be worth swapping to a later cam and drilling the extra holes for the later 4 bolt pump.
#4 Ruth's Mini
Ruth's Mini
  • 104 posts
Posted 04 September 2017 - 10:10 PM
I've been told that the lubrication system has 2 inherent problems...
1) that an oil suitable for both engine & gearbox is a compromise but nothing can be done about that,
2) the oil pump is located too high resulting in poor pressure to some areas so thought a higher capacity pump might help
we're in the process of a complete rebuild
thanks for the replies  :-)
#5 nicklouse
  • 18,605 posts
Posted 04 September 2017 - 10:19 PM
1 yes you can but not worth it on a road car.
2 if as mini13 says the old 850 pumps were lower capacity than the standard pumps now then modify to a modern version.
#6 Cooperman
  • 23,294 posts
Posted 04 September 2017 - 11:19 PM
Standard decent quality oil pumps have been working in the classic Mini for almost 60 years now.
If rebuilding an engine a new cam will be needed, so it will almost certainly require a slot-drive oil pump. The standard pump is fine for a modified 1275 engine revving at up to 7000 rpm, so it is certainly OK for a lower revving 850.
#7 Spider
  • 14,909 posts
Posted 05 September 2017 - 03:41 AM
Put a New Standard Pump in it.
It won't need anything more than that and would be detrimental to go beyond that, in terms of Oil Pump capacity (ie, gph).
#8 Spider
  • 14,909 posts
Posted 05 September 2017 - 08:03 AM
If you can't find a new Pin Drive Oil Pump, you can make an adaptor for the Cam, so it'll work with a Spade Pump
#9 mini13
mini13
  • 3,810 posts
Posted 05 September 2017 - 08:36 AM
point 2 is bullsh*t, once the pump primed suction head will have no effect on output as the relief valve is there, and if it wasnt the difference would be in the order of half a psi.
#10 Cooperman
  • 23,294 posts
Posted 05 September 2017 - 09:07 AM
If point 2 was correct one might wonder how the A-series engine has survived for almost 70 years, especially in all those race and rally A35', A40's, Sprites & Midgets, Coopers & Cooper 'S's, and usually all with the standard pin-drive OE oil pump.
The only problem with the pin-drive is that in really, really cold weather (like minus 10c)  when using the old 30 or 40 grade Castrol XL or XXL oil it was possible to snap the pin on a car with a 'cammy' engine due to the need to rev it from cold to get it to run. This didn't happen often, but it has been known a few times.
With the slot drive cam it is not an issue.
#11 Ruth's Mini
Ruth's Mini
  • 104 posts
Posted 05 September 2017 - 10:19 AM   Best Answer
thanks everyone
