I just got back my Mini from the shop where they welded the bracket on the bulkhead that is attached to the upper engine stabilizer. I replaced the engine steady mount, bushings and now the that piece is sorted, but the engine still shakes violently as I'm rolling into first, what gives? My mini has a magic wand gearbox and a 1098cc if that means anything
Engine Jolting
teddy70
, Sep 06 2017 11:58 PM
2 replies to this topic
Posted 06 September 2017 - 11:58 PM
Posted 07 September 2017 - 09:03 AM
Knackered engine mounts probably.
Posted 07 September 2017 - 09:58 AM
+ 1 as above , could also be clutch plate / cover getting a bit old & crabby
engine mounts can look fine , till you get them off & they sometimes fall apart
