Very short clutch pedal, feels like it isnt fully returning and it sits a lot lower than the brake pedal....
With the engine off I put the clutch pedal down and put the car in gear and i cant roll the car so the clutch isnt disengaging....
help!!!!
Posted 29 September 2017 - 05:46 PM
Posted 29 September 2017 - 06:53 PM
Clutch slave cylinder fitted... bled and still the same
help!!!!
I'm assuming you backed off the throw out stop nut?
Posted 29 September 2017 - 07:01 PM
help!!!!
Posted 29 September 2017 - 10:04 PM
It's the big nut on the shaft coming out of the centre of the wok, its locked with a second nut. This shaft is actuated by the clutch arm. The lock nuts stop the clutch release bearing going in too far. If it's not backed off enough it won't allow the clutch to disengage.I have no idea what thats is... so Im gonna assume I havent. (Be gentle with me Im still a mini newbie!)I'm assuming you backed off the throw out stop nut?
help!!!!
Posted 30 September 2017 - 04:41 PM
Posted 30 September 2017 - 09:41 PM
[quote name="ChrisRuffell" post="3498379" timestamp="1506711686"][quote name="Northernpower" post
]It's the big nut on the shaft coming out of the centre of the wok, its locked with a second nut. This shaft is actuated by the clutch arm. The lock nuts stop the clutch release bearing going in too far. If it's not backed off enough it won't allow the clutch to disengage.
Will have a look into this tomorrow. Wouldnt this have been a problem before though? The clutch was working fine. It wasnt until I run the car for about 15 minutes and changed gears a few times that it started to feel wrong
I wasn't aware it was ok . You are correct, it would have been a problem before but you may as well check it out.
Posted 01 October 2017 - 01:26 PM
Edited by Stevie W, 01 October 2017 - 01:30 PM.
Posted 01 October 2017 - 07:23 PM
It could be that the ball on the inner end of the clutch arm has worn or even broken off, this might explain why the clutch was ok then suddenly stopped working correctly. The ball engages with a machined hole in the clutch release bearing plunger. Theres a split pin which holds the arm in the centre boss of the wok, which is retained by a split pin.
Removal is fairly easy and this should tell you whether the ball is worn/broken!
One thing to check, which Cooperman always states to check is that you have at least 0.5 inches linear movement at the top of the clutch arm which is needed to ensure correct clutch operation!
Cheers, Steve
Posted 02 October 2017 - 06:13 PM
15A0446E-E2D6-4F16-9AA2-19F3A59A6B0A.jpeg 63.69K
0 downloads
ED633948-A0B7-4ECB-80A4-32ECFA7C63E4.jpeg 46.54K
0 downloads
Posted 02 October 2017 - 08:47 PM
Posted 03 October 2017 - 06:07 PM
407D0ADA-77EF-44FD-819D-9A0EBB3B5806.jpeg 57.73K
1 downloads
Posted 03 October 2017 - 08:24 PM
Ive held the clutch pedal down with a bit of wood and spaced it out about 6mm and let the clutch off. Does this look about right? This is a photo from the clutch pedal being up.
It's what it looks like with the clutch pedal down that matters.
