Which 12" Wheels Have The Highest Offset, Et Value?
4 replies to this topic
#1 kmckmc
kmckmc
    Just On Tickover
  • Just Joined
  • 6 posts
Posted 25 September 2017 - 02:14 PM
Hi,
I am interested to find 12" wheels with the highest ET value.
Would you point me to the right direction?   Like 12x5.5, and having the higher ET value, like greater then ET30.
Thank you.
#2 rww
rww
  • 150 posts
Posted 25 September 2017 - 05:42 PM
Positive offset, in the the region of +30's, sets the rim back in the wheel arch towards the suspension. Negative offset , usually in the -5 area, moves the rim out creating a deep dish look.
 John Brown Wheels have a poor reputation on here but we bought a set of their 6 x 12 Minilights which had a -7 offset which gave us the widest track, for racing. They do a +31 offset in the 5 x 12 Minilight.
#3 nicklouse
  • 18,625 posts
Posted 25 September 2017 - 05:49 PM
but you are best moving the rims in and out so you are not overloading the bearings etc.
#4 tiger99
tiger99
  • 8,584 posts
Posted 26 September 2017 - 09:07 PM
And, to keep the good handling, you want the scrub radius to be the same as standard. But with respect to where in the contact patch if the wheel is cambered?
And, if the wheel is very much wider, should the scrub radius be changed in proportion to the width, or fixed? There are arguments for both.
Have fun folks, tweaking your geometry. You will never get it right, only better, or worse, and in most cases, worse. Alec knew what he was doing with the back of his fag packet.
#5 timmy850
timmy850
  • 3,353 posts
  • Local Club: MITG
Posted 27 September 2017 - 07:02 AM
Have a look here too under 12" http://www.wheeldictionary.net/
Standard 12x4.5 wheels are +35 (Steel and Alloy)
JBW
12x5.0 +31 Rosepetal
http://www.johnbrown...rose-petal.html
12x5.0 +31 Minilight
http://www.johnbrown...-minilight.html
