Metro (82) Pepperpot Wheel Nuts ?
4 replies to this topic
#1 mm man
mm man
  • 405 posts
Posted 30 September 2017 - 06:39 PM
I am changing from my metric (315) steel wheels To a set of Austin metro 12" peeperpot alloy wheels (stamped NAM2728) ( 82) mk1 ?
What wheel nuts do I need ?
The wheels don't have tappers so I am guessing a sleeved tube with a flat washer type nut ?
Any help appreciated
Edited by mm man, 03 October 2017 - 07:31 AM.
#2 Mervyn
Mervyn
  • 256 posts
Posted 04 October 2017 - 05:56 AM
Sleeve nuts with flat washer, short shank 3/8 UNF.
Some for sale here
www.ebay.co.uk/itm/172903883335
Probably find cheaper if you don't mind separate washers though. Watch the shank length as you'll bottom out before the wheels are tight if they're too long.
Merv
#3 mm man
mm man
  • 405 posts
Posted 05 October 2017 - 06:52 PM
Thanks for that I have done a lot of searching for these and the ones you highlighted have been listed as a result of me asking the seller a question about another set he had advertised.
To be honest these are the only set I can find all the others like you say the sleeves are to long and would need to be modified .
The only ones that came close where D1's
Minispares went out of there way to help for which I was very grateful for but they even draw a blank.
Thanks again for your time but it looks like it's the eBay ones .
Edited by mm man, 06 October 2017 - 06:19 PM.
#4 gav
gav
  • 700 posts
Posted 06 October 2017 - 10:20 AM
Make sure you buy the correct diameter also as the sleeve nuts vary in diameter quite a bit and should match the ID of the wheels.
#5 mm man
mm man
  • 405 posts
Posted 06 October 2017 - 06:28 PM
The trader selling the nuts sent me the dimensions plus has now added them to the listing description.
They seem to be with in points of a mm difference between his dimensions and my wheels so though expensive seem like a safe bet .
Found the same nuts and checked the dimensions they are the same from johnspeed but £9 inc postage cheaper :)
http://www.ebay.co.u...119.m1438.l2649
Edited by mm man, 06 October 2017 - 08:14 PM.
