Which Rear Brake Cylinder Size
10 replies to this topic
#1 mini-mad-mark
mini-mad-mark
  • 860 posts
  • Local Club: northants wot no brakes
Posted 30 September 2017 - 11:52 PM
Hi All,
My rear brakes are "advised" every year at MoT as being not quite as good as they might
Car is a 1980 Mini City E but upgraded to Cooper S discs with Mk 3 style servo (actually Hillman Hunter) and Minifin rear drums.
I read in one of the mags that I should use GWC1102 (0.75" bore) and a manual regulator rather than a spring self setting version.
Handbrake is fine so no issue with pads or the actual mechanical parts seem OK
I have tried opening up the valve to allow more pressure but that doesn't seem to do much
What is the standard Cooper S size as it seems that would be better to start? unless anyone else can offer any ideas
Cheers, Mark
#2 Spider
  • 15,089 posts
Posted 01 October 2017 - 02:45 AM
The Cooper S had 5/8" wheel cylinders,,,,
However,,,,,
What sort of Master Cylinder do you have?
If it's  a 'Yellow Tag', then 11/16" would be more appropriate.
Get the cylinder size right first before looking to the pressure valve.
Beware of having too much rear braking.
#3 Homersimpson
Homersimpson
  • 834 posts
Posted 01 October 2017 - 06:16 AM
How have you plumbed in the servo? A 1980 mini would have dual circuit brakes but if you have added a separate servo you may have only added servo assistance to the front brakes.
I did this once on a kitcar as a temporary measure to get it through its MOT until the disc and pads cleaned up, it was interesting to drive to say the least!
#4 absx2
absx2
  • 919 posts
Posted 01 October 2017 - 08:45 AM
Very wise words as usual Moke Spider.
The car will quickly swop ends in an emergency situation with too much rear bias.
This is the bit where I get hung but I can get the rear wheels to turn with my hands on most minis with the bakes full on. Its a bit of a struggle and I am strong but it goes to show the rear brakes don`t do a lot and if they did in our lovely british climate it wouldn't take long to have a brown trouser moment.
#5 timmy850
timmy850
  • 3,385 posts
  • Local Club: MITG
Posted 01 October 2017 - 10:59 AM
There is a good list here of all the factory fitted brake combinations:
http://www.minispare...rt.aspx?1~9~105
#6 mini-mad-mark
mini-mad-mark
  • 860 posts
Posted 01 October 2017 - 04:05 PM
Thanks all,
Sorry not enough info from me now I have read my original post again
I converted to S discs WITH a single line brake setup master cylinder std 0.70" bore (think they were all the same master cylinder bore between std and S just larger capacity for S?) - and yes I understand about changing the safety aspect of dual circuit and insurance ramifications etc
Servo is plumbed to work all brakes therefore
Any further thoughts - I too do not want too much at the rear but I get earache each MoT (although I am on good terms and explain this so I get a pass)
In two years I wont need to worry if I have got any brakes at all, once it becomes MoT exempt.........
#7 cal844
cal844
  • 9,639 posts
  • Local Club: TFMOC
Posted 01 October 2017 - 07:21 PM
My advice is to ditch the servo and also match the cylinders
#8 gav
gav
  • 700 posts
Posted 02 October 2017 - 02:13 PM
GWC1101 is factory size, 0.625" bore.
#9 Swift_General
Swift_General
  • 871 posts
Posted 02 October 2017 - 04:57 PM
What rear wheel cylinders do you have at the moment? Do you habe a limiter valve on the rear?
Edited by Swift_General, 02 October 2017 - 04:58 PM.
#10 mini-mad-mark
mini-mad-mark
  • 860 posts
Posted 05 October 2017 - 07:01 PM
Hi All,
Cheers, Mark
#11 mini-mad-mark
mini-mad-mark
  • 860 posts
Posted 05 October 2017 - 07:07 PM
Thanks for the advice all  - will probably try the GWC1129 (11/16") first but will not be for a while - got to rebuild the engine for the other mini and get that back mobile again - will post the results when I do see what happens though
