Hi All,
My rear brakes are "advised" every year at MoT as being not quite as good as they might
Car is a 1980 Mini City E but upgraded to Cooper S discs with Mk 3 style servo (actually Hillman Hunter) and Minifin rear drums.
I read in one of the mags that I should use GWC1102 (0.75" bore) and a manual regulator rather than a spring self setting version.
Handbrake is fine so no issue with pads or the actual mechanical parts seem OK
I have tried opening up the valve to allow more pressure but that doesn't seem to do much
What is the standard Cooper S size as it seems that would be better to start? unless anyone else can offer any ideas
Cheers, Mark
