Cutting Accelerator Cable
17 replies to this topic
#1 Northernpower
Northernpower
    Mr. 7-Port
  • 2,414 posts
  • Name: Graham
Posted 05 October 2017 - 08:14 AM
I use a universal accelerator cable and have to cut it to length. No matter what I try I can't cut the inner bowden cable clean and straight with NO little strands left over. I've tried wire cutters, side cutters, wrapping it in tape first, even a fine bladed hacksaw. Anyone got any tips?
#2 Midas Mk1
Midas Mk1
  • 5,823 posts
  • Local Club: S.U.N.M.C
Posted 05 October 2017 - 08:21 AM
I had this with mine when fitting the SC injection kit, ended up screwing up my MPi cable.
Next one I soldered up, cut the end off, then fitted the univeral nipple on the end.
#3 Spider
  • 15,685 posts
Posted 05 October 2017 - 08:23 AM
I usually do them on the corner of a bench grinding wheel, turning the cable so the stands tighten up, if you're lucky, they will 'fuse' together a bit from the heat.
The other way I've done it is to tin (as in solder) the cable where I want to cut it, then cut it through the tinning with side cutters. Sometimes it needs a little reshaping afterwards, but easy enough.
#4 Northernpower
Northernpower
    Mr. 7-Port
  • 2,414 posts
  • Name: Graham
Posted 05 October 2017 - 08:25 AM
Well thats two votes for soldering, I've tried the grinding wheel but didn't have a lot of success.
#5 russo
russo
  • 191 posts
  • Local Club: Minis In Nelson Inc.
Posted 05 October 2017 - 08:44 AM
Yip, I’ve always used solder. (a) it makes it easy to cut and (b) stops it fraying.
#6 nicklouse
  • 18,998 posts
Posted 05 October 2017 - 08:51 AM
I just use cable cutters.
as the cycle industry have done for many many years.
#7 Northernpower
Northernpower
    Mr. 7-Port
  • 2,414 posts
  • Name: Graham
Posted 05 October 2017 - 08:58 AM
So, are cable cutters different to side cutters? If so, do you have a link?
#8 Steve8274
Steve8274
  • 580 posts
Posted 05 October 2017 - 09:07 AM
I think the key to it is ensuring the cutters are sharp. If not, they will just crush the cable before it cuts through and thats were it starts to fray
#9 minisi35
minisi35
  • 723 posts
  • Local Club: british mini club shropshire
Posted 05 October 2017 - 09:14 AM
I also second using cycle cable cutters
#10 nicklouse
  • 18,998 posts
Posted 05 October 2017 - 09:15 AM
I have these (and others)
#11 Northernpower
Northernpower
    Mr. 7-Port
  • 2,414 posts
  • Name: Graham
Posted 05 October 2017 - 09:22 AM
Tool envy  :proud:
#12 grizzler73
grizzler73
  • 300 posts
Posted 05 October 2017 - 10:06 AM
I maintain all my bikes so Bike cable cutters are a must, they will do the job, then you can solder after. I prefer to dip the end in super glue, also put a little crimp on cover on the end if you want to be 100%.
G
#13 Ethel
  • 26,580 posts
Posted 05 October 2017 - 12:05 PM
Tape and Dremel. Note the twist of the cable so you can have the wheel turning with it.
#14 Rorf
Rorf
  • 866 posts
Posted 05 October 2017 - 12:24 PM
Yip the mountain bike etc guys use small cable cutters.
#15 whistler
whistler
  • 1,870 posts
Posted 05 October 2017 - 06:18 PM
I use bicycle gear cable for my inner and solder and cut as Moke says if tape and cut doesn't work.
