Removing engine
Posted 27 September 2006 - 01:26 PM
Posted 27 September 2006 - 01:50 PM
Posted 27 September 2006 - 01:57 PM
If you car is going for a full rebuild, or major work I'd drop the subframe, otherwise, if your just repairing the engine quickly or something, I'd bring the engine through the bonnet.
Posted 27 September 2006 - 02:05 PM
Posted 27 September 2006 - 04:10 PM
"only has inner wings" i think if he pulls the engine out hed be able to it forward...dont orget about drive shafts and gear selector...it happened to my friend
aye, and good luck with the gear selector pain, I mean pin
Posted 27 September 2006 - 04:14 PM
Posted 27 September 2006 - 04:27 PM
Posted 27 September 2006 - 06:03 PM
Posted 27 September 2006 - 06:06 PM
crane!!! don't need a crane for a mini!!!
I'm only little and couldn't lift the monstoreous engines that come out of minis. Easier if doing yourself IMHO
Posted 27 September 2006 - 06:21 PM
put the car up on stands and remove the front wheels
to remove the gearbox pin, get a normal pin punch the same size as the roll pin or a tiny bit smaller and grind down a little step on it!! this helps it to locate in the middle of the roll pin!! plus have it in reverse when you're trying to knock it out! easiest position by far!
cv joints - it sounds like its ur first time so remove the cv gaitor clip from each side then take out the top ball joint on each side!! and lean the swivels over to the outside of the car!! shud give u more than enuf clearance!!
so many other things to say that cud help you but it would just take up too much room!!
remember if u have no front panel then u only have to lift the engine up a little bit to get it fowards and out!!
Edited by fikus01, 27 September 2006 - 06:35 PM.
Posted 27 September 2006 - 06:26 PM
Recon it would go down well?
Posted 27 September 2006 - 06:33 PM
DSN sell a special pin punch for removing the selector rod.
Posted 27 September 2006 - 06:47 PM
easier to remove the cups from the engine when its on the floor anyway if u havent got the tool!!
i dont remove the cv joints, just the gaitor, the cup stays in the engine!! ok the balls mite fall out of the shafts but they pop back in wth a click!! much easier to put back on that way too!! only 6 slots to line up rather than lots of splines and a locking clip !!!
ooh p.s. dont forget to drain the oil out when the engine is stil in the car!! lots easier than trying to do it on the floor or on the hoist!!
Posted 28 September 2006 - 11:44 AM
Posted 28 September 2006 - 12:21 PM
