My question is - Is the gearing for the odometer in the dial. And can that be changed or is it easier to just get a uk dial? Wasn't sure if the gearing on the diff needed to be changed.
Edited by HUBBA.HUBBA, 12 October 2017 - 06:33 PM.
Posted 12 October 2017 - 06:32 PM
Posted 12 October 2017 - 07:06 PM
The gearing within the speedo head for kmh to mph is different.
The gears themselves can be changed, but quite a fiddle - if you can get the right gears, there were a couple of different ratios.
I'd suggest you'd be better off either tracking down an mph speedo or an alternative could be to get a change speed box that is usually fitted to the back of the speedo.
Posted 12 October 2017 - 07:10 PM
Posted 12 October 2017 - 09:23 PM
Posted 21 October 2017 - 03:44 PM
Why go through all that? John Cooper sells a gauge pack .
I have a JDM Cooper and swapped to this easily. Now I know how fast I am going :)
Posted 22 October 2017 - 08:32 AM
Posted 22 October 2017 - 06:19 PM
Because, as said, simply changing the face wont fix anything.
Might look less ugly !
