Hi everyone Ive been on here for many years and built quite a few a-series engines from 998 screamers to 1275 t3 turbo builds but have now came back but in a different form - A 82 RWD Morris Ital Ex BT van. The spec for this engine build in sort is; A+ 1310cc, 12.5:1 C/R, race spec head 29x37, 296kent cam, maniflow stage 2 system, Aldon Red, MED alloy/alloy duplex, crank been fully worked - wedged, bladed, cross drilled. Rods lightend and shot peened, flywheel lightend then all balanced. Single piece prop, 3.6FD, 3J LSD ect...... I think I already know the answer to my question but just wanted to make sure, the intention for the engine is to be used for fast road/drag racing 115BHP+ Ive had this sort of spec on my mini about 6years ago but had a HIF44 and not a Weber, it preformed very well with the SU carb but this engine is pretty much built for weekends and not everyday like the mini was.
I have a problem with length (lol) with a Weber carb with a 6 inlet or even a 2 3/4 maniflow inlet it just wont fit in a Ital, Unlike the mini I cant just put a box in as the engine is facing the correct way...... the only option with having a Weber on my Ital is using a swan neck, but as I already know this defeats the object of a 45 Weber or is it actually better than a steel Maniflow inlet using a HIF44 with a ITG S/S filter? I know that usually a Weber will give around 7hp over the HIF with the correct manifold but want to know what everyone else thinks. Thank you, Pete.
Edited by Racer_Pete, 13 October 2017 - 01:04 PM.
