Hi,
1998 MPI.
I spilled a lot of clutch fluid around the master cylinder when topping it off. Didn't realise and left it for a couple of months. Saw the paint being eaten away and decided to strip it down, repaint and refit.
What I've done:
* Removed master cylinder
* Used a rebuild kit, fitting new seals, etc
* Replaced the hard line with a flex line
Once I got it back together I cannot for the life of me get it to bleed. I started working back from the slave cylinder, cracked the union on the slave, no fluid being pumped through. Cracked the union on the master, no fluid being pumped through.
I removed the master cylinder itself, held my finger over the output and pumped a few times trying to build pressure, it squirted a bit but when not covering the output it won't pump even a tiny bit out. Even pumping quite vigorously (ooh err) it won't pump out even a little.
Any ideas? Am I just bleeding it like a whopper?
EDIT: Preempting any questions:
* Yes I put the clevis back in
* Yes I am following the haynes guide on bleeding the clutch
* No I don't have an EZ bleed kit.
Edited by AeroNotix, 14 October 2017 - 12:47 PM.
