Hey there fellow Mini enthusiasts! I have a question about the sidelights.
I have a 76 Mini 1000 that was heavily modified by the previous owner. Have been restoring it back to original spec and I've swapped out the angel eye headlamps for the original Lucas sealed beams.
Problem is I dont seem to have any sidelamps when I turn on the lights. I know some models had the pilot lamp built into the sealed beam, and some used the indicator lamps as the sidelamps. What is the original spec for a 1976 Mini 1000?
The connector for the sealed beam has 3 prongs, so Im assuming one is for the dipped beam, one for the high beam, and the other is the ground?
