Hello all,
My Rover Mini 1996 wont fire. The fan belt turns when I turn the key, it's making all the right noises, but the engine wont fire.
I had recently replaced the windscreen wiper cable (both ends - more detailed explanation below) and straight afterwards the engine wouldn't start.
I have checked all the fuses in the fuse box (there are about 20 in there), the lights still work, the immobiliser light is still on, the radio still works, and the windscreen wipers work. I tried to check if there was current going to the spark plugs by pushing a spanner into the rubber surround and looking for sparks when I turned the key but I couldn't see any.
Is there an electrical fault I may have created? If so, where should I look? If not, what else can I investigate?
[The windscreen wiper cable had rusted at both ends, so I removed the plastic connector to the wiper motor and cut the other cable from under the windscreen, bared the cables, attached them to a choc box and replaced the two plastic connectors with new ones. The posi-screws holding the motor in have rusted and I cannot undo them, so I have been unable to reattach the plastic connector to the wiper motor - the cables have been reconnected though.]
Thanks for any help!
