No Reverse Lock Out/lift Up On 1997 Rod Change
6 replies to this topic
#1 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,147 posts
  • Name: Sean
Posted 26 October 2017 - 10:38 PM
I've got a '97 mpi and there is no reverse lift up/lock out.  By this i mean you don't need to lift the gearlever up to select reverse.
What is likely to be the problem?
#2 timmy850
timmy850
  • 3,397 posts
  • Local Club: MITG
Posted 26 October 2017 - 10:46 PM
There is a plate on the bottom of the change unit. There is a small "gate" which might be missing on yours
http://www.minispare...ic/DAM8621.aspx
#3 Spider
  • 15,201 posts
Posted 27 October 2017 - 12:13 AM
It could be a could of things.
The 'gate' being broken off (as tim said)
The plate being fitted back on upside, down.
The shifter housing needing aligning. If it's cocked over to the right, t will miss the gate. To Align it, loosen the big nut (1/2" UNF, 3/4" AF) on top of the shifter and then hold the body of it over to the left, then re-tighten.
Of, the bottom of the sick being worn off.
#4 A-Cell
A-Cell
  • 1,610 posts
Posted 27 October 2017 - 09:37 AM
Another possibility is that the vertical portion of the bracket (gate) is eroded away. This is caused by ignorance when selecting reverse by continually selecting reverse without lifting the lever first. I have come across this a few times on higher mileage cars.
#5 Shifty
Shifty
  • 13,147 posts
  • Name: Sean
Posted 27 October 2017 - 11:49 AM
Cheers, I'll pull the bottom of the remote and have a look.
Ive not come across this before, car isn't a big miler at 72k.
#6 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 27 October 2017 - 12:25 PM
Shifty do you mind photographing what you find? This is an interesting one!
#7 Shifty
Shifty
  • 13,147 posts
  • Name: Sean
Posted 27 October 2017 - 12:27 PM
I'll document it for posterity!!
