1997 Mpi Jumping Out Of Reverse
2 replies to this topic
#1 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,078 posts
Posted 27 October 2017 - 12:35 PM
While we're on the subject of reversing and '97 MPI's, what would cause it to not stay in reverse? mine goes into reverse but when you let the clutch out it just pulls out. it's only done 32k miles.
Edited by alex-95, 27 October 2017 - 12:39 PM.
#2 Spider
  • 15,685 posts
Posted 27 October 2017 - 11:55 PM
Could be a number of things, most likely the bushes in Reverse Gear 'walking' out.
I'd suggest checking your carpets and other things first though, just to be sure there's nothing silly from stopping it going right in to Reverse.
If everything external is OK, then there's little else but to take the box out and strip it down.
As well as the Bushes in Reverse, the Main Shaft Bearing could be worn, the small end of the Layshaft or a bad gearbox casing.
#3 Steve220
Steve220
  • 5,115 posts
  • Local Club: BMC
Posted 28 October 2017 - 01:03 PM
How much movement is there of the engine on its mounts?
