Windscreen Demisters
Posted 03 November 2017 - 09:54 AM
Thanks in advance :)
Austin Mini Mayfair 1989 1.0 L
Posted 03 November 2017 - 10:26 AM
first thing is to make sure the hoses are fitted correctly and are not leaking.
Posted 03 November 2017 - 10:47 AM
Firstly check condition/connection of existing hoses as Nick says - i tend to use gaffer tape to hold the hoses on and seal the ends.
Also check that the heater matrix is not blocked.
Also check for wet carpets - if the car is wet inside the condensation will always be much worse.
In terms of upgrades - a change to the later twin speed heater with the larger diameter air hoses is good, but the aftermarket heater from Minispares may be better (and easier/cheaper):
Posted 03 November 2017 - 10:52 AM
Posted 03 November 2017 - 12:05 PM
If you're thinking of an upgrade, why not look at a heated windscreen? http://www.heatedwin...windscreen.html
Posted 03 November 2017 - 12:28 PM
A few things,
The Mini heater is plenty big enough, what you're lacking is volume and ventilation to keep the humidity under control. Being a Mini, there's a decent chance your breath isn't the only source of water vapour.
Look at where air is entering the heater, if the ducting through to behind the grille is dubious it could be sucking in the moisture from damp foot mats or wheel spray under the wing. Later cars also have the under wing ducting lined with foam, aka sponge, to reduce noise.
As above, the windscreen vents are pants. Worst is the fit to the dash rail, stick them to it to ensure the air goes to the screen and not the space behind the bulkhead. Tape up all the joins, aluminium ducting tape is great stuff.
Service the heater, flush out the matrix and check it's not leaking. Vac out the air vanes. Use draft excluder products to ensure air goes through the matrix and not around it in the heater casing. Also that the heater flap if effective at stopping air going past it when it's in the demist position. Be thankful it's so easy to get the heater out of a Mini to do this
If you're still driving a mobile sauna a heated windscreen is the way to go.
Posted 03 November 2017 - 01:54 PM
Ethel is absolutely right. I recently overhauled my heater as part of a total restoration and it has made a huge difference. The heater is easy to remove and take apart and the flimsy foam sheet around the matrix allows the air to leak like a sieve. I replaced all the foam with 5mm self adhesive closed sell foam and sealed every orifice. Later cars have larger bore demister pipes and "Y" pieces and although I have fitted these, they didn't make too much difference. I also reconditioned the motor and replaced the single speed with a variable speed PWM controller.
All in all better than when it left the factory.
Posted 03 November 2017 - 02:37 PM
Posted 03 November 2017 - 03:17 PM
I think Mini magazine or Mini World did a picture by picture break down on a heater in the last couple of issues
Posted 03 November 2017 - 03:31 PM
Posted 03 November 2017 - 03:51 PM
Posted 03 November 2017 - 04:14 PM
Yes (or at least you should do!) - you will need a washing up bowl or similar to catch it
Posted 03 November 2017 - 04:28 PM
Posted 03 November 2017 - 07:22 PM
