Bare Metal Primer
5 replies to this topic
#1 danie garry
danie garry
    I love BMW minis
  • 2,296 posts
Posted 03 November 2017 - 01:26 PM
hi Guys,
continuing on with the build and the more i do the more i realise it isn't going to be a case of a few splashes of etch primer from an aerosol can!
looking for suggestions on a decent etch or epoxy primer. preferably something that will sort out bare metal and not be a problem over filler and 40 year old paint if it happens to spray over
i have 2k high build primer ready to go on top then
all suggestions and info welcome
thanks,
Dan
Edited by danie garry, 03 November 2017 - 02:03 PM.
#2 Daz1968
Daz1968
  • 2,058 posts
Posted 03 November 2017 - 02:34 PM
I used epoxy high build hb body 989 primer, however I did take the whole car back to bare metal as it was painted in synthetic in a previous life and was very thick. You can fill over epoxy without issue, I used upol fantastic lightweight filler,
#3 Steve220
Steve220
  • 5,064 posts
  • Local Club: BMC
Posted 03 November 2017 - 02:42 PM
Epoxy or zinc primer, either will protect again rust. Etch only aids adhesion, it will soon rust through it.
#4 danie garry
danie garry
    I love BMW minis
  • 2,296 posts
Posted 03 November 2017 - 04:38 PM
cheers lads, was looking at the 989 alright, seems like good value anyway, good to know about filling over it, i was always under the impression filler had to go onto bare metal
couple of other options if anyone can advise one way or another
http://www.autopaint...05l-14722-p.asp
http://www.autopaint...ener-4743-p.asp
http://www.autopaint...s-72-6768-p.asp
#5 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,064 posts
  • Name: Neil
Posted 03 November 2017 - 04:47 PM
Personally if i was going down that route then i would use the Mipa.
Another primer to consider though is Octoral PF131. Just used it on Paddy after a recommendation from Ben_O on here. Not epoxy but ideal for on top of any epoxy you do use. And no reaction with the epoxy primer i used either.
#6 danie garry
danie garry
    I love BMW minis
  • 2,296 posts
Posted 07 November 2017 - 03:23 PM
cheers for the recommendation, ordered some Mipa epoxy, the bigger tin worked out well as i have some other stuff to paint too
