Anti-Dazzle Rearview Mirror In Spi
7 replies to this topic
#1 brivinci
brivinci
  • 1,211 posts
Posted 10 November 2017 - 03:55 PM
Hoping someone can help here. It wasn't until the MPi did the Mini get and anti-dazzle interior rear view mirror. I find that so hard to believe as it drives me crazy while driving at night. Wondering if anyone has found a mirror that would fit on the original mounting and include this feature. I'm not interested in gluing one to the window like on the MPi. Was hoping another Rover, MG, Austin, etc would have a similar sized pivot cup that could be swapped onto the Minis mounting arm.
#2 mina08
mina08
  • 255 posts
Posted 10 November 2017 - 04:15 PM
I wonder if there is some kind of anti dazzle film that you can stick on the mirror? its really dark here in Sweden now and i noticed it the other day, would be a nice thing to have.
#3 MacGyver
MacGyver
  • 1,027 posts
Posted 12 November 2017 - 06:39 PM
Was an option on the 79 mini 1100 special, my brother has two with the dipping switch under it.
If that's what you mean?
Ben
Edit: was item CZH4000 76-85 but NLA
Edited by MacGyver, 12 November 2017 - 06:46 PM.
#4 brivinci
brivinci
  • 1,211 posts
Posted 13 November 2017 - 02:13 PM
That is exactly what I mean. I'll have a to look that up. Do you happen to have any pix??
#5 Itsaminithing
Itsaminithing
  • 855 posts
  • Local Club: Not One Worth Mentioning
Posted 13 November 2017 - 03:01 PM
....It wasn't until the MPi did the Mini get an anti-dazzle interior rear view mirror....
I was very confused reading this. The only noticeable difference between a MPI & SPI mirror is how they attach to the car.
A lot of minis were fitted with dipping rear view mirrors from mid 1977!
Later ones might be slightly different as 1993 on Rover brochures describe them as having an anti-dazzle coating (they still retain the dipping switch)
http://www.roblightb...n-brochure.html
Edited by Itsaminithing, 13 November 2017 - 07:25 PM.
#6 FlyingScot
FlyingScot
  • 2,664 posts
Would the later mirror fit on the same swivel cup ? That is use the existing stalk part but pressed into the back of the later mirror?
http://minispares.co.../CTB100060.aspx
FS
#7 r3k1355
r3k1355
  • 585 posts
  • Local Club: East Anglia
Posted 13 November 2017 - 03:09 PM
Given it's hardly the most stylish of parts why not try to retrofit an auto-dimming unit?  You'd not have issues with dazzling again.
Readily available from most scrap yards as they have been fitted to many normal cars for quite along time.
For example, this one can be found in a Peugeot 307
Edited by r3k1355, 13 November 2017 - 03:10 PM.
#8 brivinci
brivinci
  • 1,211 posts
Posted 14 November 2017 - 03:04 PM
The auto dimmer is an idea I thought about but I really wanted to try and stick with genuine parts from the incredibly large parts bin that these cars were built from.
I might just go ahead and buy that stick in mirror and if the cup is not the same, just run it. Not that I have measured but I'd imagine that the Mini uses a much smaller mirror then most cars. I actually find it gets in the way a bit so I would really not like to go any larger.
