Jacking On The Sump Cover?
22 replies to this topic
#1 MarkMcD
MarkMcD
  • 12 posts
Posted 13 November 2017 - 02:32 PM
This is just a question I want to see what people's opinions are, but whilst servicing my mini this week I wondered whether I could Jack it using the sump cover. I've seen that some folks use the sump itself which personally I would never do, but the cover attaches to the subframe which is what I use anyway. Any thoughts?
#2 Steve220
Steve220
  • 5,055 posts
  • Local Club: BMC
Posted 13 November 2017 - 02:56 PM
I wouldn't, it'd put stress on the engine mounts. Use a block of wood on the subframe.
See you're at Lossie! Spent 3.5 years there, loved every minute of that tour!
#3 FlyingScot
FlyingScot
  • 2,664 posts
Posted 13 November 2017 - 02:57 PM
What cover? Wait....what year and model?
FS
#4 nicklouse
  • 18,618 posts
Posted 13 November 2017 - 04:34 PM
no idea what you are on about.
been jacking on the sump for years. just use a spreader (bit of wood). best way to check the engine mounts as well.
#5 Dusky
Dusky
  • 5,322 posts
Posted 13 November 2017 - 04:44 PM
Sump guard probably.
#6 cal844
cal844
  • 9,625 posts
  • Local Club: TFMOC
Posted 13 November 2017 - 05:18 PM
I occasionally jack on the sump but use a 4x2 piece of wood as a spreader
#7 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,047 posts
  • Name: Neil
Posted 13 November 2017 - 05:22 PM
I think most of us at one point in time or another have jacked on the gearbox as mentioned but do check the engine mounts first. And yes using a piece of wood to spread the load is advisable.
The best thing to do though is as Steve220 said, a piece of wood that will contact both sides of the subframe.
#8 Spider
  • 14,940 posts
Posted 13 November 2017 - 06:36 PM
I've been Jacking the front ends up under the sump since the mid 70's and can't say I've had an issue from it. This is with a Trolley Jack.
I have had the odd mount fail, but they were on the way out anyway.
Perhaps some timber might be a good idea, if only to make the Jack much less likely to slip off.
#9 Cooperman
  • 23,295 posts
Posted 13 November 2017 - 09:36 PM
The OP said the 'sump cover'. Does he actually mean the sump or has he got a sump guard? If he has a sump guard he can jack on that with no worries, but I know I always hesitate to jack directly under the sump when the weight of the car goes straight into the engine mounts.
#10 MarkMcD
MarkMcD
  • 12 posts
Posted 13 November 2017 - 09:45 PM
Yeah sorry. It's the sump guard I'm on about. I've a 96 SPI Japanese Import. The guard attaches to the sub frame so looks like it should be fine to Jack from.
#11 nicklouse
  • 18,618 posts
Posted 13 November 2017 - 09:49 PM
most likely bend it.
#12 imaparana
imaparana
  • 580 posts
Posted 13 November 2017 - 09:57 PM
if its a flimsy sump guard i personally wouldnt do either, as itll bend and if it hits the sump you may aswell be jacking on the sump, ends up being an easy way to ruin some engine mounts
#13 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 13 November 2017 - 10:03 PM
wow. Always thought it was a big no no using the sump. Wouldn't it put stress on the engine mounts and shorten their life
#14 Cooperman
  • 23,295 posts
Posted 13 November 2017 - 11:51 PM
A 'proper' sump guard is ideal for jacking, but it depends whether one has a proper guard or one of those useless 'cosmetic' ones which would bend if you hit one with a rice pudding.
I always jack on mine, but I can land on mine at 70 mph on a rocky road and it doesn't damage it.
Never jack under the sump as it puts a lot of weight straight into the engine mounts in pure shear loading.
#15 Spider
  • 14,940 posts
Posted 14 November 2017 - 06:55 AM
A Caveat to my (and likely other's) posts. I wouldn't use a bottle type Jack under the sump.
As Cooperman has said in regards to Jacking under the Sump Guard, if you can't jack under it without bending it, may as well take it off as it's doing nothing what so ever, certainly not offering any protection.
