1098Cc Vs 1275Cc
12 replies to this topic
#1 Agus1601
Agus1601
  • 149 posts
  • Local Club: La Tribu Mini
Posted 15 November 2017 - 11:07 PM
Hi guys! I think my 1310cc engine is not running ok atm and needs a complete rebuild
Instead I also got an original sealed 1098cc engine that needs rebuild too
Which engine should I rebuild for perfect road/track use?
Capable of nice 80 whp with the bits needed, also would like to know about those bits for each engine
I have the money to invest asi I want it to be my daily driver and also the car for my life
Agustin
#2 nicklouse
  • 18,769 posts
Posted 15 November 2017 - 11:30 PM
the 1275.
as far as the engine goes two very different engines.
but i would be just looking a the current one. like have you seen what the pressure is yet for the fuel?
#3 Minigman
Minigman
  • 779 posts
Posted 16 November 2017 - 08:52 AM
The 1275 without doubt.
A mildly tweaked 1275 would out perform a top spec 1098 all day long, and if built well will have a lot more high rev and subsequently greater bhp capability for track use.
1098 is a fine low revving torquey road engine though.
#4 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 16 November 2017 - 10:55 AM
Agustin
Reading your other thread why do you think the engine needs a complete rebuild? From the posts you've made there's nothing to suggest it's a mechanical issue, it sounds more like a set up problem.
#5 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 16 November 2017 - 11:18 AM
   If the 1098 is a 'top spec' bored to 68 mm (1217cc)  with a good 12g295 or 1275 head, decent fast road cam and good carb it will rival any mildly tweeked 1275, as would a flying 1000cc, I've done it and seen it done many times, but has to be 'top spec' small bore. Well tuned they are good for a reliable 80 horses, and should not be underestimated, both the 998 and 1098 are highly tune-able.
#6 Minigman
Minigman
  • 779 posts
Posted 16 November 2017 - 01:00 PM
Not disagreeing on the 1098 potential being 80ish horses but if you were building a track engine from scratch the 1275 would be a better option. The 1098s dont have the 1275 potential for track use where high revs are likely needed - great for road use though. Totally agree on the 998s. Im a small bore fan, my daily is a well tuned 998 with twin SUs, 266 cam and 12G295 head and makes almost 60bhp, with 3.44FD its great for road use but I still get blown away against a stage 3 tuned 1275.
Edited by Minigman, 16 November 2017 - 01:10 PM.
#7 nicklouse
  • 18,769 posts
Posted 16 November 2017 - 01:09 PM
spend that money on a 1275 and you can blow the others into the dirt.
#8 Agus1601
Agus1601
  • 149 posts
Posted 16 November 2017 - 05:32 PM
My 1310cc engine fitted atm goes well but when I start it up and while accelerating it just leaks oil, if you put your hand in the exhaust you get it very dirty, I don´t know what that can be, but I will try first when I get it home to check the fuel pressure off the line before it gets to my pour hs4
After that I maybe changing back to the hif44 I used to have, which gave me the worst headache I remember hehe
Thanks a lot for your answers, here in Argentina we know have like 30 degrees outside so my mini cant be used
Here I leave you some pics of my hif 44 which I think it is not in good condition
Edited by Agus1601, 16 November 2017 - 05:33 PM.
#9 gazza82
gazza82
  • 3,033 posts
  • Local Club: TMF+
Posted 16 November 2017 - 08:24 PM
Exhaust could be soot from too rich fuel mix but if it is more slimy ... you could be blowing oil from worn rings/bores/etc.
#10 Agus1601
Agus1601
  • 149 posts
Posted 16 November 2017 - 09:45 PM
I think maybe I am burning oil from rings because it did not have same compression. But I should disasemble my car to do it what I dont want to atm, maybe I will do this work during hot season here so I can use it all the year
#11 ACDodd
ACDodd
  • Mini Docs
  • 2,772 posts
Posted 19 November 2017 - 08:13 AM
1098 based road engines are very capable, here is one I specced up earlier this year. However, capacity wins everytime, if you want to accelerate quickly. If you spent the same money on a bigger 1275 based engine especially a 1380 unit, it would blow the 1098 into the weeds!!
The fun thing about the 1150cc based engine below apart from the exceptionally wide torque band (in part due to using an ACD - RT camshaft), is that it was all squeezed into an 850 engine block!!
Ac
Edited by ACDodd, 19 November 2017 - 08:19 AM.
#12 Agus1601
Agus1601
  • 149 posts
Posted 19 November 2017 - 02:12 PM
Nice one! I dont want to bore my engine to 1380cc atm maybe leave it as an 1310cc and buy some cam and things to make it better
Was thinking of buying a
http://www.med-engin...mshaft-kits-934
Inserting my hif 44 and also buying a good cylinder head
But that will be as far as I can go...
#13 Rorf
Rorf
  • 866 posts
Posted 19 November 2017 - 04:09 PM
30 degrees C outside and your mini can't be used - then definitely some serious issues with your engine or cooling system.
