Mini Sounds Terrible! (Video)
Posted 19 November 2017 - 10:07 AM
https://youtu.be/uE2o23_LsQE
Posted 19 November 2017 - 11:55 AM
hard to guess the fault without being there - but -
I would get the plugs out , give em a clean , if you got a compression tester , check the cyl's (as you have plugs out)
look for a split pipe / pipe off / air leak
check the cap / points / condenser / leads / rotor arm / coil nose & terminals , use some wd40 / gt85 etc to drive out any damp
if all the above ok , look at engine running in the dark , look for stray sparks
check fuel is clean & float chamber clean & fuel getting there
report back
Posted 19 November 2017 - 04:16 PM
You the guy who had the loose flywheel problem? I think part of your problem.
Posted 19 November 2017 - 06:30 PM
Yes I am the clueless fool who had the loose flywheel
I know the exhaust has a nasty blow as when I start it up the engine bay fills with fumes and I can feel exhaust gases/air around the join between the manifold and exhaust.
Ive got the manifold off tonight. Gonna get some fire gum and new gaskets this week and put it all back together then start things up again which Im hoping will improve the sound and allow me to identify any other issues
Posted 19 November 2017 - 06:34 PM
report back
Thanks, as above I’m gonna sort out my leaky exhaust as I know that’s an issue and fire her up again later in the week and see if we still have a problem. If so I’ll go through your check list!
Posted 19 November 2017 - 07:04 PM
sounds like the exhaust may be a large part of the problem
best of luck
Posted 22 November 2017 - 12:14 AM
Your ignition light is on and off - and on - and off...
You need to take a day and do some basics...
Timing, plugs, dizzy, HT cables, clean carb, mixture, valve clearances, fan belt, solenoid...
The simple nut and bolt stuff needs to be right, clean and looked after.
The A series engine is a simple and beautiful thing but it needs to be loved and kept in shape.
Constant attention - no.
Weekly attention - definitely.
Posted 22 November 2017 - 12:41 PM
Posted 22 November 2017 - 01:37 PM
Make sure the downpipe clamp is still on at the gearbox otherwise, no matter how much exhaust paste you use you'll still get movement at the joint leading to blowing and eventually a fracture.
Posted 22 November 2017 - 01:48 PM
Posted 22 November 2017 - 04:56 PM
Ive been suspicious of my head gasket (oil in coolant/loosing coolant)
So since I had half the job done removing the manifold I decided to change the head gasket as well.
I will update with photos later
But we now have a new head gasket and cleaned out everything on the head
New plugs
Exhaust well and truly held together and sealed up.
Started her up and things sound a lot lot better
I will put a video up but it sounds worse in the video than real life.
I do agree that I think I still need to do some basics.
One thing which I cant work out. I have the idle screw as far back as I can get it but I still feel like the engine is idling a bit high and instead of a nice steady tick over it seems to fluctuate ever so slightly.
So yeah still not perfect but Im gonna give myself a pat on the back for replacing a head gasket
Posted 22 November 2017 - 05:54 PM
heres a clip of the first start up once I had put everything back together
for more pictures of what ive done today I put it all on my project thread.
http://www.theminifo...-2#entry3507726
Posted 22 November 2017 - 06:05 PM
It could be a leak on the inlet manifold somewhere, if you have the vacuum advance pipe disconnected from the distributor you need to block it up.
Also could be a bent butterfly in the carb, or wear in it's spindle.
Posted 22 November 2017 - 06:10 PM
... you just reminded me, i took that thin vacuum pipe thing off when I removed the head and didnt put it back on.
Posted 22 November 2017 - 11:47 PM
After all the bits and bobs you've done (including putting the vacuum back on) you need to do a basic tune
of the carb / engine. LOADS of articles on how to do it on this forum and the net generally.
A Rev counter might be a good addition to the dash but it does sound A LOT better : )
Best wishes
Monty
