Mini Van Fuel Tank Not Right
5 replies to this topic
#1 Avtovaz
Avtovaz
  • 1,267 posts
Posted 19 November 2017 - 07:42 PM
doing the mini van, its a 1981 car, when its left for ages the fuel drains back to tank, fuel line is empty, also, there is fuel in the tank, i dipped it, but i took the pipe off the carb and sucked and it wont come threw. Its a new stainless fuel pipe to the tank, is there inside of the tank a pipe or something that could have come off? Its been off the road for a long time, but i have had it running fine, just seems strange it drains back to tank.
#2 phillrulz
phillrulz
  • 617 posts
Posted 19 November 2017 - 08:05 PM
Just a guess, is the tank breather okay?
#3 Avtovaz
Avtovaz
  • 1,267 posts
Posted 19 November 2017 - 08:25 PM
never even thought to check!! but i think the fuel cap isnt that good, but will check it thanks!
#4 sledgehammer
sledgehammer
  • 3,108 posts
Posted 19 November 2017 - 08:33 PM
could be fuel pump valves old , or been affected by the ethanol in the petrol , letting fuel back down the fuel line
I had to replace a NOS pump because the valves went like chewing gum - a SU manual pump , the pump had never been on the road
and as above fuel vent blocked - sometimes a small hole in the filler cap sometimes a pipe collapsed
it is surprising how much vac the pump can create when vent is blocked
Edited by sledgehammer, 19 November 2017 - 08:35 PM.
#5 phillrulz
phillrulz
  • 617 posts
Posted 19 November 2017 - 08:49 PM
As sledgehammer said, my breather idea is working on the idea, the fuel pump can suck it from the tank, if the breather is blocked it makes a vacuum, when the engine is turned off air bleeds back in through the carb and pushes the fuel back into the tank
#6 cal844
cal844
  • 9,646 posts
  • Local Club: TFMOC
Posted 19 November 2017 - 09:37 PM
When we re engined my estate we had to backfill the line from the carb to pump then pump to carb, took about a week to do the engine, new mechanical pump too!
