Clutch Mix And Match
8 replies to this topic
#1 johnR
johnR
  • 2,318 posts
Posted 22 November 2017 - 09:49 PM
Once my new 1275 is re-bored 20thou, lightly ported, stage 1 exhaust and SW5 cam added can I/should I use a standard clutch?
I seem to have a mix of pre-verto (inertia starter and longer activation arm) together with a verto clutch with the little springs on the new engine.
My car is wired for the pre-engaged starter so I'd rather not have to re-do it for a separate solenoid and I'm considering a lighter flywheel.
I believe this means it's necessary to use a pre-verto clutch ? can I have a lighter flywheel with a ring for the later starter?
#2 nicklouse
  • 18,998 posts
Posted 22 November 2017 - 09:59 PM
pre eng starter means you need a verto fly assy or a verto toothed ring on a early flywheel.
just get verto arm and slave and bracket or whole Wok assy. dont try mixing and matching too much.
#3 johnR
johnR
  • 2,318 posts
Posted 23 November 2017 - 09:22 AM
My understanding is that you can't have a lightened verto flywheel, otherwise I would just use all verto and the pre-engaged starter that is already on the car?
#4 Carlos W
Carlos W
  • 10,115 posts
Posted 23 November 2017 - 10:05 AM
You can have the pre-engaged ring gear put onto a pre-verto clutch. (I did)
I believe the pre-verto can handle power better.
#5 nicklouse
  • 18,998 posts
Posted 23 November 2017 - 11:27 AM
you understand wrong.
loads of lighter and lightened Verto set ups out there.
Minispares do at least one. Med do a seriously lightened one.
so no problem.
#6 nicklouse
  • 18,998 posts
Posted 23 November 2017 - 11:29 AM
http://www.minispare...verto.aspx|Back to search
http://www.med-engin...-light-flywheel
#7 johnR
johnR
  • 2,318 posts
Posted 23 November 2017 - 01:32 PM
Ok, thanks for that - so back to the first question - is a standard Verto clutch sufficient for the power the engine will produce? I notice that the Minispares lightened Verto flywheel has the effect of uprating the clutch?
#8 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 23 November 2017 - 02:11 PM
Standard will probably be OK
But for peace of mind I would go with the upgraded and lighter one...kills 3 birds with one stone simples
#9 mini13
mini13
  • 3,811 posts
Posted 26 November 2017 - 12:03 AM
With a verto clutch you need the short activation arm otherwise you won't get anywhere near enough clutch movement.
