Which Distributor Is Right For Me?
7 replies to this topic
#1 Alfredo26
Alfredo26
  • 14 posts
Posted 24 November 2017 - 06:00 PM
Hi there!
I want to purchase a Aldon performance dizzy for my 1340. How do I know which one to get? Vacuum/no vacuum? 25d/45d ? 50d? I'm confused haha can anyone shed some light for me?
Cheers Alfie.
#2 neal
neal
  • 318 posts
Posted 24 November 2017 - 06:08 PM
If I were you I would PM AC Dodd, tell him your full spec and he will advise you accordingly. He recurves distributors to suit your application and may save you a few quid in the process.
Neal
#3 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 24 November 2017 - 06:30 PM
I imagine AC will be along soon...
#4 skoughi
skoughi
  • 1,199 posts
  • Local Club: Shetland classic car club
Posted 24 November 2017 - 06:40 PM
I sent a secondhand 45d to Aldon and told them what cam I had fitted etc. They gave it the once over and recurved it to suit my engine. I fitted a set of electronic points and it's performed very well since, although I'm hoping to get my mini onto a rolling road shortly to check everything is working as it should. I asked AC to look at it before hand but I got the impression he was busy at the time so he advised me to try Aldon.
#5 nicklouse
  • 18,998 posts
Posted 24 November 2017 - 07:34 PM
Hi there!
Cheers Alfie.
not enough info engine size has little to do with anything. as to the type the same as you have in it now. as the A and A+ also have different drives.
usage defines Vac or not.
#6 Alfredo26
Alfredo26
  • 14 posts
Posted 24 November 2017 - 08:22 PM
I want to build a fast road engine, I was told it has a cooper s cam, will be running a Webber 45, it's a A+ block is there any recommendations on a dizzy? I don't have a dizzy in it at the min as was purchased without one.
Cheers Alfie.
#7 Spider
  • 15,684 posts
Posted 24 November 2017 - 09:23 PM
Cheers Alfie.
As you're running a Weber, vac advance is out of the question.
For an A+ Block you'll need a 54D4 or later, check that it does have the right drive though as some are supplied with the earlier drive.
I'd suggest a CSI for a build like this.
#8 Agus1601
Agus1601
  • 150 posts
  • Local Club: La Tribu Mini
Posted 25 November 2017 - 08:19 PM
I am using a 123 aldon distributor on mine and works very good for me. Have a 1310cc engine that runs very good
As it is not something cheap I would recommend you to email some of the best known distributor manufacturers and tell them specs correctly
