Blue Spark From Timing Marks To Balancer
9 replies to this topic
#1 bigfish
bigfish
  • 33 posts
Posted 28 November 2017 - 09:41 AM
I heard a ticking noise from the motor and after searching located it to a spark jumping from the timing marks to the harmonic balancer.
Any ideas ?
Thank you.
#2 Archived2
Archived2
  • Archived
  • 1,093 posts
Posted 28 November 2017 - 10:51 AM
Bad engine earth
#3 nicklouse
  • 18,660 posts
Posted 28 November 2017 - 11:23 AM
more likely to be something catching. metal on metal.
#4 Icey
Icey
  • 1,552 posts
Posted 28 November 2017 - 11:48 AM
If you're sure it's a spark then it can only be HT if it's electrical - 12v won't jump air. Check you plug leads.
#5 Rorf
Rorf
  • 866 posts
Posted 28 November 2017 - 11:57 AM
Maybe you have one of the later electric engines :D
#6 slidehammer
slidehammer
  • 1,197 posts
  • Local Club: LSMOC
Posted 28 November 2017 - 01:30 PM
Could it be static electricity getting generated by the friction on the oil seal and jumping the gap?
#7 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 28 November 2017 - 02:12 PM
My first thought was you need a new earth strap, but could it will be static? could it be from the fan belt ?
12v won't jump as such, but will spark but not blue...could it be the timing pointer bent and catching...?
#8 Spider
  • 15,047 posts
Posted 28 November 2017 - 05:13 PM
Most likely from Static Electricity. They are supposed to put enough Carbon Black (or other 'stuff') in the belt so this doesn't occur.
A bit more here  http://ww2.gates.com...ts/Gf000046.pdf
I would suggest changing out the belt as it could potentially be a risk.
#9 bigfish
bigfish
  • 33 posts
Posted 29 November 2017 - 05:21 AM
i will change the belt and check the earth strap.     lets see what happens.      Thank you for all your help. This forum helps keep my mini on the road!
#10 Rorf
Rorf
  • 866 posts
Posted 29 November 2017 - 05:47 AM
Definitely looks like no earth strap connection from engine to body - linked to your loose flywheel problem also.
