Med's Itg Filter And Stub Stack Kit For The 1.5" Su
3 replies to this topic
#1 Mac1
Mac1
  • 19 posts
Posted 09 December 2017 - 07:52 PM
Hi All
I have recently purchased MED's ITG filter and stub stack kit for the 1.5" SU and I am having significant trouble fitting it.  There appears to be no way of getting the filter to clear the bulkhead in order to fit it.  I am running an MG metro manifold on a 998 a+. I have no bulkhead insulation.  So far I have removed the plastic spacer block from the manifold, but much to my amazement there is still not enough room.  Has anyone else had similar problems with this set up, and if so is there a way around it??
I look forward to any advice you can give.
Kind regards,
Phil
#2 nicklouse
  • 18,697 posts
Posted 09 December 2017 - 08:10 PM
use the longer 1275 or an adjustable top engine steady. and fit the spacer.
#3 toppers3933
toppers3933
  • Just Joined
  • 63 posts
Posted 11 December 2017 - 09:30 PM
Had exactly the same problem and removed the spacer. Its tight but it fits. Eventually Im going to fit an adjustable top steady and move it over a bit.
#4 Icey
Icey
  • 1,553 posts
Posted 12 December 2017 - 01:04 PM
Pretty much what everyone else has said - to fit ours I removed the spacer and wound the engine mount out a bit.
