Hollow Tower Bolts
17 replies to this topic
#1 pdaykin
pdaykin
  • 587 posts
Posted 13 December 2017 - 12:56 PM
I seem to remember that someone one produced hollow subframe tower bolts.
Am I imagining it ?
If not, does anyone have the details for who it was ?
#2 nicklouse
  • 18,657 posts
Posted 13 December 2017 - 01:11 PM
not hollow but light.
http://www.dsnclassi...ist-components/
 cant think who did the hollow ones.
#3 domdee
domdee
    Formally known as dominicdee
  • 1,183 posts
Posted 13 December 2017 - 03:24 PM
some one is selling some on here.
I think the tread is called Titanium parts or someithing along that line. its an ebay link.
Centres of the bolts are 'hollow'.
#4 domdee
domdee
  • 1,183 posts
Posted 13 December 2017 - 03:25 PM
http://www.theminifo...titanium +parts
wasn't far off with the name haha
#5 domdee
domdee
  • 1,183 posts
Posted 13 December 2017 - 03:26 PM
sorry looks like thay are sold now
#6 Will16
Will16
    Wants a custom member title
  • 1,090 posts
Posted 13 December 2017 - 06:34 PM
There's a few guys on build threads who have hollowed them out, this is the one that springs to mind though the pictures aren't working for me
http://www.theminifo...-clubman/page-3
Also there's this guy who made some from scratch out of titanium, proper fabrication!
http://www.theminifo...t-measurements/
#7 panky
panky
  • 1,792 posts
Posted 16 December 2017 - 06:00 PM
https://www.ebay.co....hUAAOSwAaJaNEcJ
#8 pdaykin
pdaykin
  • 587 posts
Posted 17 December 2017 - 07:29 AM
#9 mk1leg
mk1leg
  • 9,343 posts
Posted 17 December 2017 - 09:57 PM
there were some with holes drilled through for the HiLo adjustable with a 2ft long Allen key
#10 pdaykin
pdaykin
  • 587 posts
Posted 18 December 2017 - 10:40 PM
That's what I was really after
Speed bumps are causing me real problems
I was hoping for more convenience
#11 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 19 December 2017 - 12:47 AM
Pm me, I have a pair, standard type drilled
#12 PIIIOWW
PIIIOWW
  • 28 posts
Posted 15 January 2018 - 10:06 PM
Does anyone know the size of the drill holes? I dropped some bolts off at an engineering workshop today for drilling out. It'd be nice to know the required size and maintain the maximum bolt strength.
Edited by PIIIOWW, 17 January 2018 - 08:06 AM.
#13 Dusky
Dusky
  • 5,322 posts
Posted 18 January 2018 - 08:01 PM
Id drill it to 11.5-12mm max. Given its a 3/4unf bolt wich uses a 17.5mm drill hole according to my cheat sheet. Leaving a 3mm should be ample I think. As the subframe ltself is only 16gauge metal iirc. Though,personaly id never drill this, not worth the 200 gram weight loss for me
Edited by Dusky, 18 January 2018 - 08:02 PM.
#14 Cooperman
  • 23,315 posts
Posted 18 January 2018 - 10:57 PM
It is only really worth it if you need to regularly compress the rubber cone springs.
#15 carbon
carbon
  • 2,590 posts
Posted 20 January 2018 - 12:40 PM
Is drilling all the way through the tower bolt sensible? It may be sized at 3/4UNF for a good reason, and a 12mm hole all the way through the middle will make it weaker.
If you drill it out to 14mm (enough to get a 14mm thread through for cone compressor) then it will be way too thin.
If you're running all solid mounts for the front subframe then might be possible to lose weight by machining the outer part between the thread and the bolt head, bring the diameter down close to the 3/4 UNF thread root diameter (17.5mm), but leaving a small lip at top under the bolt head to locate the alloy spacer ring.
