I'm in the process of removing my engine. I have the Rover workshop manual.
Step 8 says remove the engine steady bar - upper.
Referring the section on removing the engine steady bar - upper they make it sound simple. It says remove nut and bolt. In the picture in the manual it shows the nut facing upwards. I do not have this, there is no nut on the mount point closest to the bulk head. Is it underneath therefore the workshop manual being incorrect?
Thanks,
Ben
