Rear Speakers
1 reply to this topic
#1 theoldmini
theoldmini
  • 133 posts
Posted 19 December 2017 - 08:53 PM
Fitting some 3 way speakers to parcel shelf of the mini but no instructions in the box.  They are Pye  sp93 3 way speakers in a pod.  Looking at the grill of the speakers there are two speakers in the grill and a small one on its own.  Question is which side does each speaker go.  Does the small speaker go to the middle or the side of the car.  Thanks
#2 vx220
vx220
  • 419 posts
Posted 22 December 2017 - 06:09 AM
In the back, it's not going to make too much difference. If you haven't already done it, put the smaller (presumably higher-range) drivers outside, theoretically giving a wider spread of sound.
Don't bother changing them over if you've done it already, by the time the sound gets to you from the back you're subject to an almost infinite amount of reflections, you won't notice a difference.
IIRC from BITD, some manufacturers made their pod speakers identical (i.e. no left or right, not handed)!!!
Apologies for late reply
