A+ Alternator Mounting
5 replies to this topic
#1 jonlad
jonlad
  • 325 posts
Posted 19 December 2017 - 09:17 PM
Hi folks
I am trying to mount a 45A alternator off a 998A+ onto my 1275 A+
Is this mixture workable?
So i think i've got everything the right way round, but the pulley sits about 10mm behind the water pump and crank pulley.
The top alternator bracket is flush against the water pump casting (in front of it!).
Is it common to have to add a spacer between the pump and the alternator? Or is the alternator too small?
If anyone has any pics of alternator mounting parts it might be beneficial!
Thanks in advance
Jon
PS only trying to use it as its brand new and i dont have anything else. Thanks!
Edited by jonlad, 19 December 2017 - 09:19 PM.
#2 Spider
  • 14,889 posts
Posted 20 December 2017 - 12:10 AM
They don't usually line up bang on, but that does seem a fair way off. I've seen up to probably 6, maybe 8 mm, but at 10, I'd be fitting a spacer for sure.
#3 slidehammer
slidehammer
  • 1,196 posts
  • Local Club: LSMOC
Posted 20 December 2017 - 02:28 PM
There are 2 type of alternator bracket one for pre A plus units and 1 for A plus unit, make sure you have the right one. Also check you have everything assemble properly as that seems a long way out to me.
#4 Cooperman
  • 23,293 posts
Posted 20 December 2017 - 02:47 PM
Whatever alternator you fit it is always to ensure the pulley is accurately in line with the other pulleys.
Use thin washers as spacers as necessary.
#5 jonlad
jonlad
  • 325 posts
Posted 20 December 2017 - 03:09 PM
thank you gents, it is definitely the right bracket, it came off the 998 block and matches those advertised online for A+. It doesn't hurt to check though, so thanks!
i'll pack it out and let you know how i get on.
#6 cal844
cal844
  • 9,623 posts
  • Local Club: TFMOC
Posted 20 December 2017 - 07:20 PM
The alternator mounts should be on the radiator side of the brackets.
