Dinitrol Or Similar Rustproofing Diagram
Posted 20 December 2017 - 06:19 PM
Posted 20 December 2017 - 06:54 PM
Hi does anyone have access to a dinitrol or similar rustproofing diagram for a mini. Id like to get my cars treated in the spring and these diagrams show all the access points and places to drill for spraying rustproofing fluid. Many thanks in advance.
Little or no drilling needed at all on a mini. Most if not all cavities can be easily accessed.
Inner sills can easily be reached by inserting through the vents in the outer sills.
Rear valance close outs can be accessed through the drain holes in the bottom corners or through the boot.
Floor crossmember, use either the mounting holes for the seat brackets or the floor flutes.
Bulkhead crossmember, this can be accessed from inside the car. You may have to remove some soundproofing but either side there is a large cutout where you can easily inject.
A post, this can be accessed through the door switch or the check strap.
B post, this can be accessed by removing the trim panel and then injecting through there.
