Hi,
I am currently restoring a Mk1 1963 barn find, and would like you to keep the bonnet which is rusted in the corner. To repair I need to remove the bracing, but am not sure how it is held in and what the best approach is ? It would be a shame to have to go for a new bonnet, any help appreciated.
Cheers,
Mick
Mk1 Bonnet Restoration
Mick1963mk1
, Dec 21 2017 09:29 PM
3 replies to this topic
Posted 21 December 2017 - 09:29 PM
Posted 21 December 2017 - 09:45 PM
Its spot welded at the front and the rear, and you may find there is also sealant holding it down as well.
Posted 22 December 2017 - 08:58 AM
Thanks Neil, I thought that must be the case, but wasn’t sure, you are right it looks like it’s bonded too
Cheers!
Mick
Cheers!
Mick
Posted 22 December 2017 - 09:44 AM
Although it's a different bonnet it's basically the same set up for a clubman bonnet. Several spots at the rear and sides then for the front under the lip. Quite a bit of sealant as well and bare paint. Good quality control from the factory.
