So I am part way through rebuilding the master cylinder on my mini. It is a 1996 car so has the later type servo mounted to the master cylinder.
I have removed the circlip that holds the whole thing together and pulled the plunger out, however there seems to be two separate plungers! One to operate the rear brakes and one to operate the fronts with the rear brake plunger (the one located furthest down inside the master) actuated by the front plunger via some kind of spring arrangement.
My question is, how do I remove this second plunger as there doesn't seem to be any way of getting it out due to it being too far down inside the bore of the master to grab with any tools! It also seems to have a fairly powerful spring behind it as it is difficult to press in using a screwdriver and springs back very quickly. Not sure if any of that makes any sense! ![]()
If it helps the rebuild kit is GRK1039 from minispares.
Any help would be appreciated!
