Suspension Banging Over Large Bumps
8 replies to this topic
#1 MiniGadget
MiniGadget
    Just On Tickover
  • 9 posts
Posted 24 December 2017 - 03:10 AM
I have just installed new gaz adjustable shocks/ dampers, after my koni's were said to be knackered.
I now hear a loud bang sound when I hit a good size bump in the road.
Not sure if it was doing it before, because I have only just got it roadworthy.
It is a 1965 Austin cooper s.
Old looking hi Lo suspension, will I need to raise or lower the hi lo's or do you think it would be something else?
#2 nicklouse
  • 18,998 posts
Posted 24 December 2017 - 03:16 AM
I would have said worn shocks.
But it could be anything. From incorrectly fitted parts to loose or worn parts.
Or you are expecting more from your suspension than it will do.
#3 mab01uk
mab01uk
  • 12,925 posts
Posted 24 December 2017 - 09:47 AM
Lowered Hi-Lo suspension with wrong length shocks/dampers that are bottoming out maybe?
eg. Spax dampers are available in standard length and shorter length for lowered cars, dimensions here:-
https://www.minispar...c/C-STR304.aspx
Also check all your rubber bump stops front and back are ok.
https://www.minispar...ic/FAM2764.aspx
https://www.minispar...c/2A4267MS.aspx
Edited by mab01uk, 24 December 2017 - 09:48 AM.
#4 MiniGadget
MiniGadget
    Just On Tickover
  • 9 posts
Posted 24 December 2017 - 10:02 AM
Thanks, I got the standard height shocks, because my old konis were standard also. It is reasonably high and I don't have the body type bump stops.
#5 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 24 December 2017 - 10:37 AM
It could be the radius arm, my mate had this issue,
Was actually a combination of knackered shocker and poorly reconditioned radius arms
#6 dyshipfakta
dyshipfakta
  • 1,696 posts
Posted 24 December 2017 - 11:10 AM
Could be anything though how confident are you its suspension related? Subframe mounts, engine mounts, exhaust the list is endless lol
#7 sledgehammer
sledgehammer
  • 3,129 posts
Posted 24 December 2017 - 12:16 PM
I would check subframe mounts / radius arms / etc all round
also when fitting did you prime the dampers ? (not sure if gaz dampers need this) -
hold them upright , push them thru their full travel , to force any air from the chamber ?
air in the damping chamber can make a loud knock
#8 NZMini1275
NZMini1275
  • 227 posts
Posted 24 December 2017 - 06:10 PM
I had this with my fully rebuilt car
Checked over everything and all seemed fine
Decided it might be shocks bottoming out so changed the standard mounts to lowered ones and now all good
#9 nicklouse
  • 18,998 posts
Posted 25 December 2017 - 02:51 AM
Ok let's discuss lowered shocks. The main reason for needing them is not because of the low ride height as the top stops are just the same as standard, the difference is reducing the amount the wheel drops. This can also be rectified by an 1/8" spacer under the rebound buffer. You do have the rebound buffers fitted? If not the HiLos and cones could be unseating.
