Yellow Tag Master Cylinder Won't Pump
5 replies to this topic
#1 blacktulip
blacktulip
  • 6,231 posts
Posted 24 December 2017 - 05:45 PM
Hi, I have just fitted a new yellow tag master cylinder and I can't get any pumping from it. Does it need priming or is there a trick to get it to go?
#2 Spider
  • 15,684 posts
Posted 24 December 2017 - 07:18 PM
Often most new cylinders need to be pressure bled, a Gunson's EzyBleed is handy for this.
The need for this appears to be from the grease used when they are assembled, it often covers the ports and so little or no fluid gets from the Reservoir to the Cylinder itself. Once you get some fluid in to the Cylinder, it will go like smoke.
#3 blacktulip
blacktulip
  • 6,231 posts
Posted 24 December 2017 - 08:20 PM
Thanks Moke, I have got it going now, but I have ran into more problems. It seems very strange but when I crack the passenger side front brake nipple, I get a squirt of fluid from between the two caliper halves. Obviously the seal in between has failed. I have never seen this before. The calipers are new. I wonder if this is the cause to my braking woes.
Edited by blacktulip, 24 December 2017 - 08:20 PM.
#4 Spider
  • 15,684 posts
Posted 24 December 2017 - 11:06 PM
Whoa - not good !!
I wonder if the seal is in there at all?
#5 blacktulip
blacktulip
  • 6,231 posts
Posted 25 December 2017 - 12:48 AM
Not sure but I will be taking it off and returning it asap. It seems very strange it squirts out only when the nipple is open.
#6 AlexMozza
AlexMozza
  • 1,248 posts
  • Local Club: Not Yet
Posted 25 December 2017 - 02:37 PM
Ive seen this on Chinese non gen ones.
Ive also had new ones where the calliper pistons return in the housing, giving long pedals and a pain to bleed!
