Windage Tray + Centre Main Strap?
Posted 30 December 2017 - 07:09 PM
John
Posted 30 December 2017 - 07:25 PM
yes, there will be a ton of room below the strap, its the big ends that would be the issue if anything.
Posted 30 December 2017 - 08:29 PM
Posted 30 December 2017 - 10:51 PM
Posted 14 October 2018 - 05:46 PM
Holly thread resurrection Batman!! I recently tried to fit a Guessworks gearbox with windage tray to an A+ 1275 with the MED centre mainand found the MED strap bolt fouled the windage tray. My advice would be to look at a centre strap that uses countersunk cap screws that is able to retain the bolts with the profile of the strap.
Posted 14 October 2018 - 06:24 PM
While I'm not a believer in Centre Main Straps on these Engines, I doubt you've ever be able to Torque up Countersunk Main Bolts to the right level. Because of the Countersink, the Inhex Tool is quite small and it will likely break well before getting to 60 ft/lb, while I've not used them here, that's been my own experience.
Posted 14 October 2018 - 06:43 PM
If you need a windage tray you would be better off having a 4-bolt steel main cap made and the block line-bored rather than a main bearing strap and longer bolts.
Posted 14 October 2018 - 07:05 PM
had no issues running both years ago sounds like the MED strap is well fat.
Posted 14 October 2018 - 10:27 PM
Posted 14 October 2018 - 10:34 PM
