Mems Single Plug, Pin Wiring Diagram.
8 replies to this topic
#1 M111OWW
M111OWW
    Woody
  • 126 posts
Posted 30 December 2017 - 08:39 PM
Tying This into my post about my on going battle with getting the specialist components ECU working properly.
Would anyone have a pin diagram also showing what colour wires run to what pin for the single plug MEMS ECU for 1995 Spi cooper..
It was a brand new Auto Sparks loom that I fitted 3 years ago.
All the original ECU and associated sensors all work fine, however I need to be 100% certain that all the wires are in their correct position before I chuck the ECU back AGAIN.
#2 Mike L
Mike L
  • 159 posts
Posted 30 December 2017 - 11:02 PM
Maybe this one?
http://www.theminifo...ttach_id=188600
#3 M111OWW
M111OWW
    Woody
  • 126 posts
Posted 31 December 2017 - 12:26 PM
Maybe this one?
#4 M111OWW
M111OWW
    Woody
  • 126 posts
Posted 31 December 2017 - 12:27 PM
Thanks Mike, Ill check against my plug when Im home on Tuesday....
#5 viz139
viz139
  • 694 posts
  • Local Club: Irish Mini Owners Club
Posted 31 December 2017 - 01:51 PM
If its a '95 with the 24 fuse box in the engine bay its slightly different from the above  diagram. The Alarm changed to the 5AS so you will find a white/gray wire on pin 13.
#6 Mike L
Mike L
  • 159 posts
Posted 31 December 2017 - 03:16 PM
Where did you find this diagram? I redrew every wire diagram I could find online ( http://www.theminifo...agrams-redrawn/ ) but I didn't find that one.
#7 viz139
viz139
  • 694 posts
Posted 01 January 2018 - 05:17 PM
If you read through the posts in your link you will see that I offered to supply the diagrams for SPi 95-96 that I have created like the one above.
#8 Mike L
Mike L
  • 159 posts
Posted 01 January 2018 - 08:07 PM
I must have thought I had them covered. Apparently I didn't. We should add them to the list with credit to you. And thank you. It would be fantastic if we could gather all the known diagram variations in a single place for everyone.
#9 M111OWW
M111OWW
    Woody
  • 126 posts
Posted 02 January 2018 - 06:47 PM
Thankyou gents, all pins checked and in their respective positions/colours..
Everything is exactly as it should be..  Fantastic diagrams, easy to read..
