Just Brought My Mini And The Garage Are Questioning The Wheels
99 replies to this topic
#1 M700FGT
M700FGT
  • 135 posts
  • Local Club: LSMOC
Posted 17 January 2018 - 11:53 PM
Hi all,
Just brought a 1997 Rover Mini Cooper MPI Sports pack on a P reg. (Its also my first post on here)
Its in the garage as it needed a few things doing before i could enjoy him. Problem is the front Camber is really out and the front wheels rub on lock.
The guy i am dealing with has three much older Mini's and tells me the wheels i have are the wrong ones as they have spacers. Hes checked the arches and confirms they are correct and genuine, but is convinced the wheels are wrong.
They are 13 inch and look exactly the same as all other sport pack wheels i have checked on google images. Ive looked online and many people say the car had spacers as standard.
He told me to buy new wheels so that they would fit correctly and as i also have two bald tyres. Been on Mini Sport and the Cooper Sport Wheels they are selling look identical to what i have.
Can anyone help me as i think im going a little Mad. Picture of my car attached.
Marc
#2 Ethel
  • 26,111 posts
Posted 18 January 2018 - 01:15 AM
Sportspacks did have spacers (10mm?) on the rear.
#3 tmsmini
tmsmini
  • 743 posts
  • Local Club: MOASF
Posted 18 January 2018 - 03:30 AM
What size tires?
#4 MacGyver
MacGyver
  • 1,027 posts
Posted 18 January 2018 - 07:04 AM
You shouldn't have spacers at the front if that's what you mean?
It also look a bit low at the front, but that MIGHT be the picture. 🤔
Ben
#5 miniireland
miniireland
  • 175 posts
Posted 18 January 2018 - 07:31 AM
could the steering rack have been replaced with a non sportspack item, as those racks were specific
#6 Fast Ivan
Fast Ivan
  • 2,910 posts
Posted 18 January 2018 - 07:42 AM
there should only be spacers on the rear
check that the wheels are actually genuine, they should have ROVER cast in them
was the car originally a sportspack option or has it been done at a later date? The bodywork needs trimming around the arch to fit the large 13" wheels and this may not have been done if the sportspack arches have been added later
are the tie rods straight?
Are ant of the suspension components adjustable, including hi-lo's? as said it could be a bit low
#7 ings
ings
  • 201 posts
Posted 18 January 2018 - 07:54 AM
First i would change the garage. this shoul de a easy fix. You definitly dont need new wheels.
the sportspack have 5mm spacers at the rear.
if something with the camber is wrong, check the suspension cones and knuckles.
#8 Midas Mk1
Midas Mk1
  • 5,790 posts
  • Local Club: S.U.N.M.C
Posted 18 January 2018 - 07:56 AM
First impressions, run from that garage, and find a classic, preferably Mini specialist, or local club for advice.
They are indeed standard fit wheels, and as above, rear wheels on sportspacks have a small spacer, 5/6mm iirc to clear the shock.
Edited by Midas Mk1, 18 January 2018 - 07:57 AM.
#9 Archived2
Archived2
  • Archived
  • 1,093 posts
Posted 18 January 2018 - 08:49 AM
Could be a non cooper sports pack with the arches and wheels added later meaning it has the wrong steering rack. No spacers on the front with either mini. Just the back with SP mods
#10 nicklouse
  • 18,727 posts
Posted 18 January 2018 - 08:54 AM
first things first check what the wheels actually are.
wheel off and look at the casting marks.
#11 Midas Mk1
Midas Mk1
  • 5,790 posts
Posted 18 January 2018 - 08:56 AM
As a note, even factory sportspacks come up on stupid car part systems as 12x4.5m 145 tyres, not the factory fitted 13x6's..
Edited by Midas Mk1, 18 January 2018 - 08:56 AM.
#12 Itsaminithing
Itsaminithing
  • 855 posts
  • Local Club: Not One Worth Mentioning
Posted 18 January 2018 - 10:21 AM
Marc, i think the Garage is right in that they are the wrong wheels for your car - don't panic!
My guess is that you have a 1997 Mini Cooper that someone has fitted with Sports Pack wheels & arches without fitting the limited travel steering rack -hence the tyre scrubbing.
(Sports Pack option cars had 2 front fog lamps & 2 front driving lamps, also oil temp & voltage gauges amongst other things).
You have two options....
1. Change the wheels        &/or wheels + arches + wings!!!!!
2. Buy a set of these for £15.05 + p&p :-)   https://www.minisport.com/kad1012230-kad-mini-steering-rack-limiter-kit.html
#13 cal844
cal844
  • 9,660 posts
  • Local Club: TFMOC
Posted 18 January 2018 - 11:23 AM
Rack limiters won't solve the issue if the tyres are catching the front of the arches, it could also be that the arches have been replaced, without the wings being cut?
#14 miniireland
miniireland
  • 175 posts
Posted 18 January 2018 - 12:23 PM
Hi all,
Marc
any photos of the car from different angles, are the knuckles shot, or possibly hi-los fitted and bad geometry
#15 ukcooper
ukcooper
  • 1,625 posts
Posted 18 January 2018 - 01:29 PM
Some mpi's where fitted with 12" wheel up until the end in 2000.1 3" started in 1997 as a upgrade
some had 13" wheel fitted with arches ,steering rack, wings ,rear spacers , rear subframe , dampers ,space saver as well me thinks = sports pack
over the years the 12" versions have been changed to 13" with out doing a propa job .
ya log book may help if it sez copper = 12"
sports pack =13" but don't worries if it dose not as it depends what the person wrote down when the car was first registered varies quite a lot .
just looked on mine reg doc for the mini and its called a rover mini sport but I know its a sportpack.
take it a propa mini garage if ya want to know, not aa back street one .or a local good club ..
my 10p worth
Edited by ukcooper, 18 January 2018 - 01:35 PM.
